200+ woodworking book reviews
Christmas ornament help
GalenV in Iowa
>I have only attempted one elliptical globe for a Chritmas ornament and that was end grain with a home made hex wrench hollowing tool.
Results: catch working through small opening and now split in two.
What is a good reference book, dvd, youtube video, etc. that I can learn how to turn the small globe and finials?
Is there a best hollowing tool?
I have read the WoodCentral post on ornament proportions. If I need to turn the 50 John Lucas says I've got a long way to go to learn proportions! Read the post on screw eyes for same and that helps.
I assume the end grain are easier to turn and will be a while before I try segmented or cross grain.
Any directions would be helpful.
Thanks
Galen
Re: Christmas ornament help
>By elliptical I assume you mean sort of a flattened circle. These can be difficult because you have to reach around a somewhat flattened bottom. Much harder than round or egg shaped.
First of all you don't really have to hollow it thin. These don't weigh as much as a larger ball ornament. You could easily get away with whatever wood you could hollow with a straight tool. This would leave the bottom and outer edges thick but no one but us woodturners would notice or care. In fact I just photographed 16 of this style for a friend who needed a business card. His were noticeably heavier than mine but he doesn't have any trouble selling them for $35.
If you do want to hollow them further use a bent tool. It doesn't have to be bent very far (about 45 degrees). The tip should not extend very far. It's hard to control the torque if you have a long tip and that's where the big catches occur.
If you make your own tools leaving the tip short isn't a problem at all. After you sharpen it a bunch of times it gets short. Just reheat it, straighten it, then bend it where you want. Then heat treat it if you need to. I use drill rod which makes it very easy to do any of these but you can do that with an allen wrench.
Below is a photo of my bent tools. The one on the top is HSS silver soldered to the rod. It is the grabbiest. Not because of the steel but because of the angle and length of the cutter. The bottom one is my most used which is obvious by the short length of the cutter. It's been ground a lot. The 1/4" cutter takes a smaller bite than the 5/16" which also makes it easier to control but it chatters too much on my deeper ornaments so I go with the bigger shafts for these.
Thanks John
GalenV in Iowa
>From just a posted picture of an ornaments it leaves one not knowing if they are left solid, just a bored hole or truely hollowed thin. Well, except for pierced it's pretty easy to tell!
I was still working on a few tools I could use. I have 1/4" drill rod I will make into a round skew and one a straight hollowing grind. I have a 1/4" boring bar from my metal lathe days and it takes a 1/8" drill rod that is set at 45 degree. Got the steel and handles turned, just not mated together yet.
May be wrong for a new turner like me to attempt so many different things to turn before I get one close to right. I have not tried a mirror yet, but maybe down the road.
Thanks again,
Galen
Re: Thanks John
>New turners can turn the same things the pros do. It just takes longer and maybe you can't go quite as thin. I've seen a lot of work over the years and I'm always surprised by the work that beginners do. I've had people in my classes that had some wonderful pieces. Then I see thier skills and wonder how they did it. However I think back at my own struggling efforts and realize that I did the same. I just took lots of small bites, usually with a scraper and then sometimes sanded it to death. Still I got there.
Where beginners fail most often is in design of the piece and the sanding and finishing. Design is simple. Look around you and see what others have done. Not just wood, there are designs everywhere. Lamp shops are great. They have all sorts of things in glass, metal, and ceramic that can trigger an idea for a shape in wood.
Sanding is just paying attention, looking hard, and using good light. There shouldn't be any sanding scratches. I just spend an hour and half sanding a 17" bowl. I moved the light every which way and looked for those errant marks.
Finishing is easy if you sanded well enough.
HeatherA in AK
>There are books with sections on hollow ornaments by both Bill Bowers and Dick Sing that are both very helpful.
HeatherA
GalenV in Iowa
>Thanks Heather.
I see my new Craft Supply Woodturners Catalog 2009/2010 has Dick Sing's book "Turning Ornaments & Eggs". Bill Bower includes an ornament on "7 Great Turning Projects for the Small Lathe".
Will check one of the local stores Monday as well.
Galen
Re: Christmas ornament help *LINK*
Darrel
>Galen
this might help
http://aroundthewoods.com/projects/instruction/ballicicle/biornament01.html
Making a Ball and Icicle Christmas Ornament
Thanks Darrell
GalenV in Iowa
>Putting web sites in my Favorites has gotten totally out of hand for woodturning, which may be a fault of newer turners trying to save everything.
I need to come up with a better directory system especially for personal web sites that have a bio, gallery of turned items to learn from and have helpful instructions or videos.
Wood Central folks post a LOT of good information but even that is hard to remember who posted and how to find. Searches here are hard to find things again since the subject lines vary even though for the same topic.
Thanks again
Galen.
