Turning for glass blowers
Mike Foster
>I have been approached by a glass blower to see if I would turn some molds for him. The idea seems like fun and a bit of a challenge, but was wondering if anyone here has any experience with this. The glass blower says they usually like their molds done in wet fruitwoods. Finding a piece large enough may be a trick (he needs a mold to reproduce a glass lamp bell for Whoopi Goldberg). I would think that a large (12 at it's wideset) mold of fruitwood would be prone to checking and cracking. If anyone has experience with this I would be interested in talking with you, perhaps by phone.
Mike
Re: Turning for glass blowers
>No Experience at all turning for glass blowers, but soon with fruit wood. Cherry is prone to warp as it dries. Apple tends to warp and crack dramatically. I have had several large pieces of both. The cherry was wonderful, it warped as it dried and I turned it a second time and made a reasonably stable bowl from it (actually, many bowls). Turning the apple was pleasant, but the failure rate was terrific, probably over fifty percent. Bradford pear was wonderful. Not a lot available except after storms, but great to turn and fairly stable.
Because these wet turnings will warp, sometimes dramatically, do they use them wet as a once off thing, and then toss them? They might be able to use it over and over for a day or two, but you can't keep them wet too long or they will salt or rot.
Make them one, let them use it, Send it back to you and turn it again into something interesting. Maybe it would become a bowl that is scorched inside.
Re: Turning for glass blowers *LINK*
ET
>If you google "glass blowing" lots of links to hot techniques for shaping hot glass will come up. Or search youtube for the same.
At 4 min. 40 seconds this video has a dripping wet fruitwood wooden block being used to shape a bowl. The wood has to be used wet.
ET
http://www.youtube.com/watch?v=O1xb48Y6EdA
>Mike I was asked but they never followed threw. The molds they are using are for shaping the glass while it's hot. They store them in a bucket of water so you don't need to dry them. If you need info I will ask my glass blower friends. I know they have had students at the craft center wood program make them for the glass department.
The only ones I've seen are made out of 1 part. The handle and bowl are all one piece of wood so you would need a lathe that has a pretty good swing.
Keith Tompkins
Keith Tompkins
>Mike, I visited the Sandwich glass museum in Cape Cod. They were generous enough to give me a private tour of the molds they employed, usually made from mahogany. Turners and carvers, usually from Germany, made the wood molds which were then used as patterns to sand-cast cast iron. The iron molds became the permanent molds. the workmanship, as you may expect, was outstanding. While I was there, a glass blower was demonstrating the use of green wood as a mold.
Ralph
>Mike
Dave Schweitzer (owner of D-Way tools and a turner) works with some glass-blowers, you might get intouch with him and see what he has to say
His work
Mike Foster
>Thanks for all of the responses. I've been back in touch with the glass blower and have a little more information now. He sent a couple of pictures and they show the molds with separate handles attached, so having a huge swing for the handle shouldn't be necessary. He even said that the large end of the form could be open and he would use a separate board to close off the end while shaping the glass. This makes hollowing the mold and smoothing the interior a whole lot easier. He did say that cherry would work, so that is probably the wood of choice since the wide part of the bowl is about 12".
From the pictures of the molds it looks like they try to keep an even thickness (but pretty thick). The result could be cut in half on a bandsaw and hinged, then handles added like the two in the picture. If they are kept wet, then warping and shrinking probably is no problem. He's going to pay a visit here to explore the idea further. If it all works out, I have a feeling I may become a local resource. There are at least 3 glassblowers near me, and it seems there is no-one around that will make their molds. I don't really seek commissions like these (or architectural turnings) but I think it would be neat to help out fellow crafters/artists. BTW, I have watched a couple of these artists in action, so had a pretty good idea of the process but was unaware of their use of wooden molds.
Mike
Mike Foster
>Here is a picture he sent of the final product he is after.
Cherry
Jorge Castaneda~Downeast Maine
>Mike,
Cherry is a fruit wood, isn't?
Easy to find any size you need.
Re: Cherry
Mike Foster
>Jorge,
It is a fruitwood and seems to be the best choice for this applicaiton.
Thanks
mike
