Can I thin CA?
Can I thin CA?
Can I thin CA?
>I have some thin CA that has started to thicken. Sometimes it sits in the drawer for months without a problem and sometimes not so Much. So, what I have now is getting a little syrupy. Is it ruined? Can I thin it? With what?
Re: Can I thin CA?
Re: Can I thin CA?
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>Acetone would appear to be the proper solvent for too thick CA glue, but getting the proper ratio of solvent to glue may be a little tricky. I would add very small increments, stopping to test the product (will it set up and form a good bond).
I read a report a few years ago of a woodtuner who always purchased thick CA glue and then made his own dilutions with acetone. Considering the expense of CA glue, I have not had the nerve to try this. But you have nothing to lose?
Re: Can I thin CA?
Re: Can I thin CA?
Russ Fairfield
>Try thinning it with acetone. You have nothing to lose. You could also try using it as a thick glue, but be prepared for some funny curing characteristics, and maybe having to use an accelerator to get it to cure at all.
My experience is that old CA glue is old CA glue. Old age is an irreversible process in glue, humans, and finishes. The glue has become thicker because it has started to do a slow cure in the bottle.
Thinning new thick-CA glue is a totally different story. It is thick because it was formulated that way, not because of old age. My experience has been that that doesn't work very well either.
Re: Can I thin CA?
Yes, but I wouldn't
>Cyanoacrylate adhesives are generally speaking monomeric in nature. They consist of monomers, sometimes in a solution. They undergo an initiation that can be triggered externally (the spray can of activator) or internally (by free radical initiation from within caused by exposure to water or the like).
Your thin CA has probably already started to polymerize. Yes, you can thin it - sort of like thinning polyurethane with mineral spirits. The thinned CA will NOT have quite the same properties as the thin CA. As it is partially polymerized, it will not flow into the cracks, voids or whatever as easily. It may work reasonably well for larger cracks.
Just remember it will probably have different properties.
Re: Can I thin CA?
Re: Can I thin CA?
Peter Lamb
>JL,It sure is wonderful to have such knowledgeable folk in the forum.Thanks for sharing your smarts.
Peter
Re: Can I thin CA?
Dick Hines
Re: Yes, but I wouldn't
Dick Hines
>Good greef Bary, You need to do more turning. My CA supply always seems to be on the low side. It is goin way before it goes bad.
Re: Can I thin CA?
Re: Can I thin CA?
Wally Dickerman in Arizona
>Barry, when you put time, effort and possibly money into a piece, why would you want to screw around with questionable glue? Toss it.
Wally
Re: Can I thin CA?
Ding, Ding, Ding, We have winners......
>Dick is right, I need to do more turning. Haven't done much lately. And, Wally is right. Any turning I have time to do shouldn't be trusted to aging glue. And Thanks JL, your chart reminded me of the Bible, I did not understand any of it, but it was wonderful.
Re: Can I thin CA?
Re: Yes, but I wouldn't either..........
Barry Turner
>I just wouldn't mess with CA in any way other than what is described on the label. Recently, I was flowing some thin CA into some hairline cracks in a turning. I was holding the piece wrapped in a towel in my hand. The CA overflowed from a crack, soaked through the towel and promptly glued my thumb to the towel and also to the turned wooden object. The chemical reaction of curing was accompanied by a very rapid heat build-up, which burned a blister on my thumb before I could rip it loose. I have a brand new respect for cyanoacrylate glues. I would not attempt to thin old or new CA because of the risk of an inadvertant spill and possible injury. CA is serious stuff. Handle with care!
Re: Can I thin CA?
Amen!
Barry Turner
Re: Can I thin CA?
Re: Can I thin CA?
Juergen
>This is how I do it. I buy 16 ounces of medium and keep it refrigerated. In most cases the bottle will last 18+ months without any noticeable degradation.
I fill two small plastic squeeze bottles, one with 2 oz. the other with 1 oz of CA. I then add and additional ounce of Acetone to the bottle with 1 oz.
I've found the 50/50 mix achieves a viscosity close to thin/super thin CA sold in your favorite store. You can play with the ratio; however I would not go more than 50/50. When filling the bottles insure they are clean and avoid any contamination. If you follow this system you will have wasted only 1oz of glue if things go bad on you.
If you're not confident the thinned CA will fix a small crack, use it only for punky wood. It penetrates well and is usually activated by the punky wood. Wearing latex or nitrile gloves will prevent burn blisters should the glue run and activate on your hands.
Re: Can I thin CA?
Katherine Kowalski
Re: Can I thin CA?
Katherine Kowalski
>Wearing latex OR nitrile gloves never prevented me from getting CA burns... The CA eats through the material fairly quickly, and starts to burn your fingers.
I advise NOT wearing any gloves, (as bare fingers are easier to wipe on a paper towel than are burning fingers remove from a tight-fitting glove). I would just tend to advise being neat and tidy about applying CA (avoiding getting any on the fingers at all...)
