More on dust masks..............
Richard Jones
>Didn't want this buried below in the original thread, so............
Couple of folks were asking about the mask sizes: I am a pretty big boy, 6-2, 240, and I use a medium. I can't imagine going larger, unless I had a beard. The fairer gender would probably benefit from the S size.
Again, great mask, easy on/off, quick replacement to the filters, which seem to last forever. Just unscrew and toss, screw new ones on, about 30 seconds total.
Again, thanks to Barbara for the steer.
Rich
Re: More on dust masks..............
Thanks Rick-I'm pretty small so small it is.
Yep
Barbara Gill, Remlik VA
>I have two respirators. One is a medium and one a small. The small fits better.
I Did not know.....
>they came in sizes. I went to Grainger and bought one and it fits. They did not offer me a choice, I just took the one they put on the counter. It has an "M" right on front of the nose, so I guees its a medium. Of it was built for Marvin or Mary.
Has anyone else noticed that no matter how much weight it gains a chicken never gets fat in the face?
Re: I Did not know.....
Carole Valentine
>Mine is a small and it could even be smaller. Contray to what Barry says about chickens, I do lose weight in my face. My hat is even too big! LOL
Re: Yep
Carol Reed - home in Strawberry
>Thanks, Barbara. Small it is. I'll let you all know how it fits.
>Unless they have changed their stocking Granger has different sizes. I guess the guy just knew what size to give you.
LOL that is a picture, chickens with double chins.
Another thought *LINK*
Joe Pack
>My 2 cents on dust masks...
I bought the DustBGone because it worked over a beard. I used it a couple of times and hung it up. I figured if I could taste the cocobolo and padauk dust, I was breathing it also.
I tried the cartridge type and found it too heavy, plus, it didn't seal very well with my facial hair.
I now have a Triton helmet system that I like and use when turning heavier things, but my "go to" mask for most small work is one by James Duxbury called the Resp-O-Rator. It is by far the lightest, most comfortable and most effective non-helmet device I have ever used, and conveniently fits under a face shield. Plus, no fogging of glasses. Filtration is 99% @.3microns. Cost is about $40. Filters are replaceable. It is a funny looking contraption, but it works and works well. 10 minutes of getting used to it, and I never noticed it after that.
The Resp-O-Rator is shown and is available at the web site below. No affiliation, just a VERY satisfied customer.
Resp-O-Rator
P.S.
Joe Pack
>The Resp-O-Rator is shown with a nose clip which I found annoying. It took just a couple of minutes to learn not to breathe through my nose. Much more comfortable in my opinion.
Re: fitting a dust mask..............
Henry (Raleigh NC)
>When a former employer closed their facility, I was able to take home a box full of masks with a selection of sizes and brands of half masks (nose/mouth) with both particle and chemical filters.
Size and brand DO determine the fit - as the 3M brand, size Large is the only one I can wear that does not leak somewhere. I have a large head and broad nose and so many masks as too narrow at the top to seal.
The easy way to check fit is to close the exhaust port (seal it with your palm) and exhale gently. If you feel "breeze" in a certain spot then the mask has not sealed. Perform that check each time you don the mask. We had boxes and boxes of them because individuals were fit with specific masks - not all size M masks, even of the same brand, fit the same. We were using them for Haz-Mat work, and so proper fit was essential.
Never having purchased these retail, I am uncertain how to go about getting the right fit for a mask when all the products are in sealed packages. I do know what the right fit is and that a properly fir mask that seals is the only one worth using. Cost is not really an issue there. Performance is.
Henry
