Whats your thoughts...
Paul Zerjay
>on spraying cocobolo with lacquer?
Paul Zerjay
Re: Whats your thoughts...
>Haven't turned any in a while but I made lots of wine stoppers from it a few years ago. I've been using lacquer on them for quite a while so I probably sprayed those. I don't remember having problems. The good thing is lacquer is very easy to remove using lacquer thinner if it doesn't work.
Carole Valentine
>What's the use of the piece? Unlike John, I tend to stay away from lacquer on utility pieces like bottle stoppers that will be handled a lot. It's a little too "filmy" and looks like crap after significant use so I prefer an penetrating oil. If I do use lacquer, on an oily wood I wipe it down first with some solvent like acetone, let it dry, then apply an initial coat of thinned lacquer (50/50), then when that is dry I proceed with the regular "strength" lacquer. This seems to give it a better "bind". I'm certainly no expert on finishing, but that's just how I do it - right or wrong. Maybe Russ will chime in here with his vast knowledge of finish characteristics.
caroles method works well
bob davis
Paul Zerjay
>Carol
This piece is a vase that's really not going to be handled. It's more artsy than anything. (Not good for anything really, 'cept to look at) I did a pre-wipe with acetone, but I went straight to "full strength" lacquer with no undercoat.
Re: My thoughts...
Ron McKinley
>For cocobolo and other oily woods I use for bottle stoppers I use Myland's sanding sealer (lacquer based) and buff it out lightly with steel wool then take it to the Beall Buffing System. No other finish.....Ron
Keith Tompkins
>Hi Paul, Martin guitar co. used a vinyl sealer under a lacquer finish for many years to finish rosewood guitar backs. Oil finishes have proven unreliabe on many woods in the rosewood family....they sometimes will not cure. I don't know their current finishing techniques; nearly everyone has switched to water based finishes.
Carole Valentine
>Thanks, Keith. It's good to be aware that there can be a curing problem. Luckily I have not run into that yet, but it's good to know. On really oily woods like blackwood, I don't use any finish at all.
