McNaughton Cutter question
>I loaned my McNaughton system to an acquaintance. He kept it several months and dropped it off at my shop. When I looked at it, I was astounded that he had completely disassembled and put it back together in a very strange ways. I put it back together correctly and put it away. He had taped the sharp ends. I took this to be a good thing.
Today I used it for the first time since it was returned. The cutter dulled almost instantly. I sharpened it and it dulled again. This is a pretty snarly piece of walnut, but it nearly knocked the end off the sharp end.
I finally looked at the cutter closely and realized he had ground the top surface. On this cutter he ground the hardened surface insert completely away. On the others, what is left appears to be very thin, maybe a 1/32"
I have the "standard" set, Its the middle one that is ruined. It cuts about a 10" bowl.
What can I do? Can somebody silver solder or braze a new insert on it? Can I order a single knife? Any idea how long the others will hold up with half the insert thickness ground away?
