Battery Charger/Pyrography
TomCollins
>I have an old battery charger I want to use for pyrography work. I can switch it between 6 & 12 volt output. I would like more control over the heat and was wondering if I should lower the voltage before it goes into the charger or should I lower the output voltage to the burning tip. My concern with lowering the voltage before it goes into the charger is that it will damage the charger. Would a router speed controller be heavier and work better than a lamp dimming switch?
Thanks for any help you can provide
TomC
