>I need to attach my lathe to the floor to prevent it moving, especially when coring. Problem is, it is in the basement and I don't want to drill holes in the concrete. I have the only completely dry basement in the neighborhood.)
I have been looking for some kind of mount that can be epoxied to the floor, but with no luck. Does anyone know of a solution?
>I can understand your frustration. I ended up building a ballast box and putting in several hundred lbs of gravel. I can still move my lathe, but not easily.
>My good friend had the same problem. He was turning vessels with holes in the sides and had to run the lathe at high speed to get the cleanest cut. I mounted 3" angle iron that was 5 feet long to the feet of his powermatic. It stopped the walking and vibration. It did create a trip possibility but his shop is large and has lots of space so he just marked them clearly.
I don't think you'll have much luck gluing your lathe to the floor. Even if you tried, the adhesive would pull the surface from the concrete. A wider foot print, and/or more mass, is the way to go.
If you haven't done it all ready, put a weight box under your lathe and fill it full of fine stone (sealed in plastic bags for ease of transfer in the future). My Jet 1642 has about 300# of stone in it and it does me well. Mass is your friend in turning. I turn a lot of bowls to the maximum diameter of the lathe. Yes, it does still wiggle at certain speeds with certain out-of-balance work pieces, but that is my clue that the machine has reached a critical frequency. Dialing the speed a little below that reduces the vibration, and also, stress on the machine.
My fear in bolting a lathe to the floor is that you may stop if from moving, but this false sense of security would allow you to run more out-of-balance items on your lathe, causing much higher stresses on the head stock & earlier failure rates of your machine. Just because the lathe is bolted to the floor & rock solid, your work piece will still be out of balance and prone to failure by centriphical force.
When a lathe is jiggling badly, it is trying to tell you something.
>I agree with the other posts,add more weight.This topic often comes up in our club,and my response is,once you anchor the lathe to the floor,when you turn off balanced material,something has to give.I feel if the lathe doesn't move,your headstock bearings are going to take the brunt.It's like a bridge,if it doesn't sway,it will fail somewhere.
