Do you figure this is dry yet?
Steve Kubien
Steve Kubien
>Hey folks,
In April I salvaged some elm from the roadside tree-cutting crew. I do not know if the tree was living when they took it down but I assume it was not (no other reason to take it down where it was). Anyway, I turned some spindle-type blanks to 3" x 12"+ in hopes of using them for peppermills and anchorsealed the ends, plus 2" or so up the length.
Until today, I last weighed them in July. As an example, one of them weighed 1124g in July and weighed 1115g today. 9 grams in 4 months says to me they have got to be very close to dry. Either that or the anchorseal slows things down more than I thought.
What do you think? Ready to go or leave them because the anchorseal slows things THAT much.
Thanks,
Steve
Re: Do you figure this is dry yet?
Barry Elder
>If you turn them right away, they will warp and crack like crazy. If you leave them alone and weigh them every day they will weigh the same every day. In my case it's called the "Gotcha" law. Something like Murphy's Law but then maybe not, or somethin'!
Rick_Allen
>Give then a couple more years
Gary Evans -- Tallassee TN
>Steve,
9 grams of the original 1124 is only .8% of the total weight which isn't much. Unfortunately, that doesn't tell you anything since you don't know what the moisture content was when you put them up.
The only way to know for sure is to weigh a piece, stick it in the oven and then weigh it again. That way you can calculate exactly what the moisture content is. If your scale is accurate enough, you can do this with a very small piece of wood. Well worth the sacrifice to know exactly what you are dealing with in terms of moisture.
Gary
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
>Steve, if this was a board 3" thick, you would be looking at about 3 years for it to dry. From April to now is only 6 months. Unless you put the blanks in a hot attic, they have just begun to dry out.
Roy Girolami
Apex, NC
Steve Kubien
Thanks folks
Steve Kubien
>Ya, I figured the 3-years-for-3" was more appropriate than what the numbers were telling me. I suppose a moisture meter would be helpful in a case like this.
Back on the shelf they go.
Thanks again.
Dick Coers
>I agree with all that they are too wet. But, you can now speed up the process a little. Rough turn the od, and undersize bore out the center. Raffan does the trick on his boxes by cutting off the lid, rough turn out the i.d., then tape the rough lid to the body blank for the final drying. Around here, the furnace is running a bit regular. I put blanks on the main trunk line leaving the furnace. I start with the wood pretty far down the line, then move it towards the bonnet on top of the furnace. If you do the rough turning, and then move them along the duct, I bet they may be ready by Christmas.
>I agree with what's been said above and especially Dick's message. It's been my experience that a 3" square piece will dry much faster than a 3" board. Still it will take longer than 6 months to guarantee good results. Rough turning and drilling will speed it up but you do risk losing it. I try to wait a year but mine are usually cut 2 feet long. If I'm going to make a box out of it I wait longer or I rough them and let them dry another month or more.
The best thing to do is to constantly cut up wood like this and put it away. Then when you need some it will already be dry.
Steve Kubien
John, do you mean...
Steve Kubien
>...planning ahead? That's not my strongest trait. Oh look, something shiny........
Steven Antonucci
It doesn't matter
steve antonucci
>In general, I suppose it would be nice for everything to be perfect and round, but if you are making a peppermill, a little bit of movement probably won't matter.
I suspect that once you cut it, it will be more moist than the current surface is, but if you are concerned, rough them out before finishing. The inner wood being removed and the rough shape will allow for faster drying. I've turned a couple that were "green" with no ill effects.
steve
Re: John, do you mean...
fredbear34
>ROFL! I think that maybe we were cut from the same stock.
Katherine Kowalski
Re: Thanks folks
Katherine Kowalski
>Cindy Drozda has an excellent paper on building your own convection drying box -- which cuts down the drying time immensely. (Far better than "leaving it on the shelf.") It works by constant air flow and is very easy to build.
http://www.cindydrozda.com/Assets/html/Portal/handouts.html (on the right under "Technical Papers": "Low Tech Drying Kiln"
I can't pass up something shiny :)
Mike Brazeau
>Steve - I have processed quite a number of similar spindle blanks over the last three years. If it were over the winter when the house humidity is very low, my guess is that they would be dry to 8-10%. Over the summer I roughed out a bunch of cherry and with the house at 65% humidity, they dried down to about 12-14% in three months. I have a cheap Princess Auto meter that bottoms at 8%. Exterior surface were below that but fresh cut read 12%. Your blanks are probably in the 14% range but center may be slightly higher. I am finding the total weight loss to be about 25% when I reach that stage of dryness.
Brad Vietje
Re: It doesn't matter
Brad Vietje
>I'll add one idea:
As long as the original log was big enough, it won't usually matter (much). As Steve and other have suggested, rough turning can work for pepper mills as well as for bowls.
BUT, if they were sawn out of smaller stock, so one edge is relatively close (or closer) to the pith, you could have problems and lose a few.
Have fun! Live big! Try one...
Safe spinning,
Brad Vietje
Newbury, VT
Wayne Fladby
>Steve, I thought you were from thr Toronto area.
I'm suprised that a roadside tree crew would let you take elm, because of the Asian Beetle thing going on. Were they government
guys?
Steve Kubien
Steve Kubien
>Hmmm, I did't write that very well. The crew was not there but the wood was. This was also about 1/2 hour east of Toronto but yes, they are being more careful about such things.
Steve Kubien
Oops, this was meant for Scott Burr
Steve Kubien
Steve Kubien
No it wasn't. I'm going back to bed. Sigh
Steve Kubien
