Spalted Maple
Woodie49
>Hi,
I turned some Spalted Maple, and it came out uneven. What went wrong, what could I do different?
Thanks
Spalted Maple
Woodie49
>Hi,
Thanks
Re: Uneven- photo please?
Jamie Donaldson
Re: Spalted Maple
Woodie49
>By uneven I ment no round. No photo.
Re: Spalted Maple
Sean Troy
>You need some spalt evener
Did you turn it "green" and then let it dry?
>They will often go out of round when you do that.
Re: Did you turn it "green" and then let it dry?
Woodie49
>It was dry when turned.
Denis Putland
>Woodie,
To get constructive help in a situation like this a picture is worth many thousands of words.
Denis
Re: Spalted Maple
Randy Johnson Connersville IN
>I think the problem he is talking about is one I have experienced several times as well.
When spalted wood has large areas that have gone punky you are turning a piece that is going to be waaaaaaaaay out of balance because the punky wood is lighter than the more solid sections. Even if it is turned between centers it will NEVER run true. The end result for me is bowls with uneven rims.
If there is a way to stop this problem I haven�t figured it out yet.
By the way, in a few days I�ll try to post a picture of one of my recent adventures in spalted maple.
Re: Spalted Maple
Woodie49
>This it!It looks like it's round, but it's not.
Thanks
Re: Spalted Maple
Doc Green
>Woodie, Did you sand it? How much and what grits?
The punky areas will sand away much faster than the harder wood and give a surface with dips and valleys. ~Doc
Re: Spalted Maple
Woodie49
>I started with 80 down to 150.
Re: Spalted Maple
Barry Elder
>It can also happen with some wood if the tenon is on the bark side of the piece. I have several that I have experimented with. The wood is more stable if the tenon is on the pith side of the piece.
Re: Spalted Maple
Sean Troy
>With punky wood, coat some sanding sealer on the solid wood, a couple of coats. When thats dry slop some 50/50 mix water and white glue on the punky stuff several times after each time has dried. The glue should help even things up a bit for finish cutting and sanding. Sand at slow speeds and very little pressure if any. lrt the paper do the work.
Re: Spalted Maple
>My problems with punky wood start way before the sanding stage.
If I start with say, a 16 inch bandsawn blank, I will still be out of round after the diameter has been reduced to under 14 inches. What�s more, I think I could go down to 6 inches and it would still be out of round. It doesn�t seem to make a lot of difference what kind of cut I make, heavy, light, or very light. The �ghost� image never goes away as long as the lathe is turning. I�ve seen some things turned from wood that looked borderline rotten so at the present I�m chalking up most of my problems to lack of experience. Things should be better by the time my shavings pile blocks the view of the nearest neighbor�s house.
Re: Spalted Maple
Don in central washington
>super glue the tang on the bottom so it does not compress or warp
as u tighten the chuck when roughing I do it all the time on my
spalted maple
turns right off as u finish with vac.
