200+ woodworking book reviews
Wood Hardener Results
CGelnett
>Several weeks ago I asked what wood hardener works best and received all kind of input. Many I never heard of before. The attached picture of a bowl I made using the 50% Spar Urethane and 50% Mineral spirits. The original ruffed out wood only weighed about one pound but after brushing on several coats it more than tripled its weight.
The pictured I took is a little distorted. The bowl is 10 inch high 7 inches at the bottom and about 5 inches at the top. The wood is silver maple log that had been laying in my back yard for the past three years.
Re: Wood Hardener Results
Umm, Well, Yea, OK...
Scott Burr in Ben Lomond CA
>Your pic is SO large when clicked upon that it looks completely picsulated (sp). Nice looking vessel though!
Glad it worked out.
keith zimmerman, Normal IL
>Looks good Chet. I'm glad you were able to get the wood firm enough to turn. I like using this stuff to harden the wood. It really seems to be the easiest way to go. It's also a lot less messy.
You say you brushed on several coats of the mixture, did you apply those coats as you progressed through the hollowing, or all at once?
keithz
CGelnett
>Keith what I did was to turn down to a rough shape on the outside of the bowl first. I applied the solution with a brush all around the bowl several times (normally I went around till it did not look dry) and then let it dry for 4 hours. I did that twice on the outside but on the inside had to do it in stages or steps the deeper I went in.
