Re: Mike Mahoney tools
ChukkB
>Although I didn't get to talk to him personally, I did get a look at his tools at SWAT a couple of weeks ago. I had to smile when I saw his "signature" tools.
The "Bottom Feeder" is a bowl roughing gouge. The "Cleaner" is a traditional bowl gouge, and the "Wood Beater" is a swept-back bowl gouge. The grinds on the "Bottom Feeder" and "Cleaner" are what trained woodturners were using years and years ago.
The bevel angles and side angles on all of them are 40 degrees. The heel is relieved further after grinding the bevel. During the Mahoney/Stuart Batty rotation at SWAT, their grinder had platforms on both wheels; one platform setup at 40 degrees for the bowl gouges, and the other was setup for skews. After sharpening the gouges on the 40 degree platform, they would relieve the heel on the one setup for skews.
The thing that peaked my interest was being told that these profiles can't be had with a jig... you have to grind them by hand. If the jig is set for the front bevel angle, then the angle will be off when you go to grind the sides. In order to get a consistent 40 degree bevel you have to do it by hand. I didn't have much time this past weekend, but I'm in the process of experimenting with hand grinding using the notes I took at SWAT.
I'm interested in what others can add here as well.
