Online Lighting Diagram Creater *LINK*
Robert Lemon
>I've been surfing --- found this site which allows you to make a lighting diagram for your photos. Also, has sample pictures with the diagrams. Enjoy!
http://www.lightingdiagrams.com/
Robert Lemon
Re: Online Lighting Diagram Creater
>That's rather silly. You have to see what a light is doing. You can't see how it's creating shadows or how the highlights look. It would be totally useless for shooting what we make.
Years ago when I first started shooting artwork I made polaroids for testing the lighting. I made diagram similar to what this program would do. I found them totally useless. Sometimes moving a light just a few inches or angling it one way or the other a few degrees will make a huge difference in how the piece reflects that light. A drawing, even with polaroids to go along with it, were very little help.
I developed the photo booth idea to make things as simple as possible for beginners. It definitely isn't the go to for everything and I rarely use it in my work but then I have $20,000 or more in lighting equipment to help me modify the light.
If you build a photo translucent photo booth and light it evenly(through the panels not directly) with 1 light it will do a decent job of representing the work.
The most important thing is to light balance your camera to the light your using. Move in close so you fill the frame with the object. Focus accurately (auto focus rarely works to your best advantage) and use a tripod to support the camera. Find the right exposure by bracketing (over and under exposing) if necessary.
After that it's just a matter of playing with the light. I have found that you can bounce the light off the ceiling to light the booth more evenly. It does require much longer exposure times but that's what the tripod is for.
Neal Addy's site is much more useful to woodturners. I don't have it bookmarked on this computer.
http://www.nealaddy.org/node/16
adrien
Although photography is a process....
Jamie Donaldson
>...of painting with light, sometimes the KISS process is best in practical application. Both John and I know that most turners are well served by a simple light enclosure that gives good repeatable results for least expenditure of money, funds that could be used for more wood or tools! Learning how to correctly adjust camera functions is often more important for achieving good results with simple lighting techniques, and time buying and playing with expensive studio lighting equipment is time lost at the lathe.
Re: Although photography is a process....
Marc Phillips
>"Learning how to correctly adjust camera functions is often more important for achieving good results with simple lighting techniques, and time buying and playing with expensive studio lighting equipment is time lost at the lathe."
I can sure attest to that! ... once I set up the phrugal light set up the rest of the learning curve has been ALL camera...
Thanks-bookmarked it on this computer
Bill Crommett
>My biggest problem is getting color correction. I bought a Canon power shot SX110-IS because it has a 10X optical zoom for natyure fotos. But the only way i can get a decent color representation is by using the flash, which does no great turnings photography. I even dug up a couple of old slave flashers I had but they over exposed everything on the Ato settings. I have not been able to get any good color correction settings on the camera, so i am back to using the old 35 mm.
Minalta. Help ?
>Your camera should have a tungsten color balance. If you use bulbs that have a 3200 degree Kelvin balance then you should get good color. If you are shooting in a room that has colored walls you could pick up some color from that. You don't say what lamps you are using to shoot with. If your camera only has automatic color balance then you are fighting a losing battle because even the color of the wood can throw it off.
Re: I have some bad news for you Bill.....
Jamie Donaldson
>....., and that is you will have to read the instruction book! That camera has a good selection of 6 color balance presets which should match most of your possible light sources.
Bill Crommett
>Bad news : Now I have to READ !
I have been trying to use halogen work lites, because I am too shaky , and none of the color adjustments on the camera give me the color rendition that is as true as the flash color. The slaves were trying to get rid of the shadows, but I don't know how to adjust for the exposure. Is it too little , too much or is the synch off ?
The camera has a plethora of settings that don't show up in the intended sequence and I get confused in the section where it tells me how to brush my teeth or how to start the lawnmower.
The camera color balance symbol of....
Jamie Donaldson
>.....a light bulb should give a good match for Q/H work lights, but I'm not clear about what photo you are referencing?
Re: The camera color balance symbol of....
Bill Crommett
>I wil look for the light bulb. Thank you .
>Bill Quartz halogen lights should be very close to accurate for the Tungsten setting on your camera. I use them at home and even though they are a little low on the Kelvin scale they are so close I don't need to adjust the color in photoshop unless I just want to nail it perfectly. Most people would not see the slight color shift.
>One other thought. Is your monitor on your computer accurate or color balanced. That will throw off the color an awful lot. I don't know how to do it on a home computer. We have a very expensive gadget and very expensive monitors at work to get the color right. I got lucky and my home computer is very close without doing anything.
Gary in Zirconia, NC
>Bill,
One other thing, when I shoot with tungston, I shoot it at night. That way there is no chance of daylight from windows affecting the shot. One of the worst things to do is to mix lights and it is imposible to correct.
Gary
Bill Crommett
>Thanks, Now I only have to find where in the book it tells how to change the color balance.
