How do you finish a shellac finish?
Richard Jones
>I've recently been applying about a 1 1/2# cut of shellac to a few bowls. For those of you who do this, how are you rubbing this out? I've been re-chucking and using 600-800 grit paper at very low speed with almost zero pressure, but one turns out well and one doesn't, i.e., some scratches in the finish. For the ones that don't turn out well, I'm contemplating going back with something like 320, going all the way through the grits again, then applying another coat of shellac.
Any and all info welcomed, and thanks for your help.
Rich
Re: How do you finish a shellac finish?
Bill Clark
>I use Zinsser Seal Coat shellac as a sealer on almost all of my turnings. Yes, any scratch marks left from the prep sanding will show up but better now than later. From my experience it's not the shellac that's scratched but the remaining sanding marks prior to the application of the shellac. Simply sand the piece again with the higher grit papers and reapply the shellac. You may have to do this 2 or 3 times until the scratches are entirely gone. While you are doing this you are sealing the wood so fewer top coats are required. Another advantage is that shellac drys in about 15 minutes allowing for a quicker prep time. Then apply your top coats of whatever you use. I use Minwax Satin Wipe-on-Poly. Usually 2 coats of this will fill the very small scratches that are left behind. One note of caution. Only use dewaxed shellac. If you are using a shellac that has wax in it (and most do which is why I use Zinsser Seal Coat) it will cause problems for any other type of finish on top of it, especially a polyurethane such as Minwax.
Barry Turner
>You only mention the finer grits of sandpaper. I would hope that you are sanding with progressively finer grits starting with something like 180-grit or maybe even coarser, depending on the quality of your tool work. It is important not to skip grits. Go through the progression of 180, 220, 320, 400, etc. Your problem is likely in the sanding, not the finish. If you prepare the surface properly by sanding thoroughly, your choice of finish becomes much less important. As one old guy once said, "Put the polish on the wood, THEN apply the finish."
Mike Mills
Mike Mills
>I am not a finisher but here is what I do.
First make sure all the scratches are out of the wood. An overhead light will not work most of the time. Use a task light at a sharp angle to the wood and dampen with mineral spirits while turning by hand on the lathe. Many scratches will show up that will not with and overhead light.
Now your question. I use shellac for the base for almost everything. I first thin a small amount of 1 part to 3 parts DNA for the sealer coat. If it is not glossy in areas I apply more coats until it is all glossy. When dry I then take a towel and dampen it with DNA and hand rub the object to remove all excess shellac (all of this on the lathe with the lathe off). The shellac is melted instantly and is easy to remove. If in doubt use a clean towel just damp with DNA, rub lightly with the lathe on. I usually sand lightly with 400 grit with the lathe running. Then apply your topcoat as you wish.
My problem was not with scratches but with proud areas when too much Mylands (or other topcoat) was applied with the lathe running. The shellac would build up in a spot and could be mistaken for scratches.
Mike
Dick Coers
>I use shellac as the final finish on my Christmas ornaments. I sand the shellac to 600, then two or all three of the steps with the Beal Buff. The number of steps depends on the color of the wood. ie. no white diamond on walnut.
I really like using Abralon when I'm polishing wood. It last forever. If I'm power sanding, they make 3" velcro pads.
Another tip for taking out tough sanding scratches on wood (walnut especially) is to take a slightly damp cloth and dampen the wood at somewhere around 320 grit. It will swell the wood fiber some, and it seems to make sanding out any fine scratches easier.
Richard Jones
>Task lighting, yes. De-waxed, yes. Sanding through complete range of grits, yes.
This isn't my first boat ride, and I'm very anal about scratches, so this has me baffled. This is a particularly stubborn piece of African mahogany, which always seems tougher for me to finish. I'll start over and see what happens. Bottom line is that I've never encountered this except with shellac, which leads me to believe it's the finish, but pride goeth before the fall, and all that. It may be easier to DNA-wipe the piece, that would surely help in trying to figure out what's going on.
Maybe some pics if I can get my camera to behave.............
Thanks, guys, for all the good points.
Rich
Robert Lemon
>Rich, The previous posts are right on regarding going through the grits, moistening with solvent, and inspecting under various lighting. I think one other problem that people are having with Seal Coat is that it has water in it. Any sanding that is done with dull or dirty sanding paper will drive fibers down rather than cut. Then when you put Seal Coat on, the water raises the fibers back up. That is why scratches reappear. Before any sealer or finish is applied, it would be a good idea to lightly moisten the wood so the compressed fiber could be re-sanded.
