Re: Inertia Sanders ( Non powered)
GaryG in MD
>Jake, I like them very much for the outsides of things, and I agree with Dennis' comments. I end up with a much better scratch pattern. OTOH, also like Dennis, I would not consider using them on the inside of a bowl -- they don't work well near the center because the linear speed of the wood is too slow, and they are too dangerous near the lip. For the inside, I use the powered sander. The downside of using a power sander is that if you get heavy handed and don't keep rotating the piece or the disc evenly and constantly, you can easily oversand it and make an asymmetrical dip. The other concern is that the sapwood is often softer than the hardwood and sands out much faster -- also leaving a less than desirable situation. (Of course you also have this problem if you sand by hand.) It's much better to learn to do a good job with the cutting tools and sand minimally and at higher grits. Easy to say... ...Gary
