Large drive center
Sean Troy
>Does anyone know where to get a large 2 prong drive center at least 1 3/4 " 2MT? Thanks for any help, Sean
Large drive center
Sean Troy
Re: Large drive center
>Bestwoodtools sells some that fit in your chuck. 2 or 4 prong.
Sean Troy
>I'll check into it, thanks John !! Sean
Jennifer@Indy.USA
>Sean I use this one John is talking about I love it. I bought the one for my Stronghold but it seems to work fine in my Talon as well. I thought it might goof up the rings on it using it in the Talon but it hasn't. One size fits both.
Jen
John and Jennifer...
Steve Kubien
>...when I use a spur centre, I hammer it into the work piece with a wooden mallet. Do you do similar with this one from Bestwood or do you rely on the tailstock to apply enough pressure for it to stick? It looks really awkward for the way I am used to doing things.
Thanks,
Steve Kubien
CSUSA has them on sale
DavidWalser
>Sean,
Craft Supplies USA has the Best Wood Tools drive center on sale in it's clearance section. The versions for some chucks are sold out.
Re: John and Jennifer...
>Steve I don't have the bestwoodtools. I have one that screws onto my lathe spindle. I picked it up used. It has a threaded aluminum rod that you screw in and then hammer on that. I use a dead blow of course. The problem I have is the center pin is too thick and it's hard to drive that in. I've started drilling a hole in the center and then I chisel two cuts for the jaws and now I don't have to drive it in anymore which was kind of a hassle anyway. It only takes 4 hits with the chisel. 2 straight down and 2 at an angle to clear the chip. This goes in deeper and seems to hold better than before.
I had this one before Vic came out with the other one. Of course I have to remove and reinstall my chuck all the time. With Vic's you don't have to do that. It looks good but since I have never used one of them I can't comment on how well they work. They are solid aluminum. I would guess if you use a deadblow hammer you won't damage them by hammering but I don't know that for sure.
I built one using a nut and 3 long ground teeth. It works great on really odd side pieces or where I don't want to take the time to remove the bark. I think I'm going to build another one that has shorter teeth and a spring loaded center pin. That should solve all of my problems.
mike hamilton
>The latest email flyer from ChoiceWoods has something called the Big Bite from Oneway at a very reasonable price. I can't find it on the Oneway site, so maybe it is pretty new. It's a flat bladed affair with a center point and two prong ends on the blade. Made to fit in the jaws of any Oneway chuck. You might give Clay an email on this.
Regards,
Mike
Jorge Castaneda~Downeast Maine
>Sean,
I saw the one pictured on Mike Hamilton's post in action last weekend, it works just fine.
I don't know what is your intended use, for my live edge pieces I use a shop made one, it is a faceplate with bolts with sharpened tips on all holes, held in place by nuts; works very well and costs very little. Of course, when you are doing something else, the bolts come out and you have a normal face plate. Give it a try
Jorge
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>I am interested in how one would use this and why, Does it do something you can't do with a screw drive in the chuck?
Skip
mike hamilton
>Doing your roughing betwixt centers does allow some options for changing orientation for grain balancing that you don't have with a screw. If you rough between centers, this item gets you past the tendency of wet wood to slip on a standard drive center.
Regards,
Mike
Sean Troy
>Thats a thought. The reason I like the large 2 prong is exactly why it was mentioned before. Changing orientation and thick bark.
Re: Large drive center *LINK*
Walter Ahlgrim
>This one is made in the USA
Can be used as a four-blade or two-blade drive.
Blades are steel and can be removed for regrinding or
replacement.
Center point is steel and is removable for regrinding or
replacement..
Center point extension is adjustable.
Please note link under photo
Walta
Drive Center
Jerry Whitaker
>Craft Supply had this one at SWAT last week for $17.95.....$2 off the regular price. I should have bought one.
George Van
>Sean, I have the Jumbo Chuck Drive Center from Packard, a two spur that chucks in my Stronghold chuck. I prefer my modification to Al Stirt�s three prong drive. I use it for most blanks that I wish to orientate.
Al�s mounts in the chuck by way of a tenon and is convenient as you do not have to take the chuck off. Mine was made by mounting a thick piece of aluminum to the faceplate with hardened bolts to create the spurs.
George Van
