Stumbled Onto Gold Leaf Substitute
charlie belden
>If you've ever tried to gold leaf anything with sharp edges or corners - or grooves - you know how much "fun" that can be.
And if you've substituted metallic spray paint for the gold leaf - and tried to do different colors adjacent to each other you know how much "fun" that can be - masking off areas - unmasking and remasking areas, . . .
I've been using Prisma Color Premier markers, the one with the fine tip on one end and a broad wedge on the other, on my last three Magic Wands - in very light maple. The results were pretty saturated colors - great for kids' wands but a little intense to an adult eye.
So for the oak wand I'm almost done with, the Prisma markers were too translucent to cover the oaks light brown. The results were BLAH.
What I needed was a white paint to cover the oak where I wanted to color with the markers. So off to the box with the dyes and airbrush paints where I found FASKCOLOR's Paint for Lexan - Faspearl White - a semi-opaque pearlescent water based airbrush paint.
Two coats of FasPearl White, half hour to dry, and started applying the Prismacolor - orange and yellow for "gold/"bronze", red and yellow for a "ruby", blue and purple for "saphire" and green and blue for "emerald". Now the idea of applying two colors of marker to an area seems like it wouldn't work - but Primsacolor has a "blending" marker that has the solvent for their color medium which lets you - blend colors - as the name implies.
The resulting effect looks quite a bit like "leafing" / "foiling". Oak, with its open grain, wasn't the best wood for this technique - but it hints at what can be done on a wood like maple.
Looks like I've got ANOTHER wand to turn to see if this idea pans out.
ps - the maker of FASKOLOR is - General Electric Company. Talk about diversification.
