A55 Smoothing Plane
PM 3520 Cover Needed
Brad Vietje
Brad Vietje
>Hi Folks,
I have a 3520-B, and about 2 years ago I lent the plastic cover to a friend who needed to move a washing machine on a snowy day...
I guess he didn't understand how important that plastic bag was to me, and he tossed it out. Since my lathe sits in an unheated barn, it can be a challenge to keep the dew off it when the temperature/humidity changes (which is does a LOT around here).
So now I'm looking for a PM "bag" or a suggestion for a good cover. I'm wondering if a large BBQ grill cover would be the best. If anyone made or bought a cover for theirs, and still has the bag she came in, I'd happily exchange wood or cash for it.
Safe spinning,
Brad Vietje
Newbury, VT
Re: PM 3520 Cover Needed
Sean Troy
>I think you could find a large Grill cover like you mentioned. It would be durable.
Re: PM 3520 Cover Needed *LINK*
Philip Morris
>Brad,
Don't personally have experience with these, but they appear to be designed to do just what you are describing. They probably would hold up better, too.
Machine Covers
>Just get one of those blue tarps that is large enough a and lay it over the machine.
Philip Morris
>Oh yeah, forgot to mention. I cover my tablesaw with one of those picnic table cloths that is plastic on outside and a felt on the inside. Works well and is cheap (if you don't mind your tools looking like a picnic table).
Ric Taylor
A Motorcycle Cover Might Work
Ric Taylor
Dick Strauss
>Brad,
Wax your beds first!
Now I'm going to throw out a wild suggestion here...get some waxed produce boxes from your local grocer. Cut them to fit over your lathe bed with a little overhang and wrap a few bungees around it to keep it in place.
Wild enough for ya? I know the price is right (free if you ask). I think the waxed carboard won't absorb moisture and keep it against your lathe bed like regular cardboard would. It should act as a barrier and not allow the moisture to get there in the first place.
Don at Central Illinois
>I personally think you should let me 'store' it for you in my heated shop! You could visit anytime.
GalenV in Iowa
>I had to store a metal lathe and drill press in an unheated garage in Iowa and found the best cover was just a twin fitted sheet so that it could breath through it. Eleastic corners helped wrap the tools. Did the same with motorcycle till a got a good fitted breathable cover.
Made the mistake one your of coating drill press with WD40 spray and found it a gum ball in the spring. It actually held moisture then.
In a barn do you have to worry about critters building a nest under any cover or must it be critter tight?
Galen
Plastic Pockets
Gil Jones...Georgia
>Brad,
I have a roll of thick plastic (.005") pockets. The pocket dimensions are about 104" long opening by about 66" tall. I just unrolled one, detached it from the roll, opened up the 104" pocket and slipped it over my PM3520B. It completely covers the unit with the headstock all the way to one end, including the 18" bed extension. Plus, it goes all the way to the floor enclosing it all which includes my tailstock turning tool holder (which is now holding 40 turning tools). If you want one it is $5 + shipping to you via USPS flat rate box (if it will fit in that box). So figure $15.00 total. I bought these ages age during a home move to cover mattresses, and have not unrolled any more of them since. Working on a picture.
Pictures of plastic pocket cover on lathe
Gil Jones...Georgia
Re: Pictures of plastic pocket cover on lathe
Gil Jones...Georgia
Joe Herrmann
>Brad:
I think I still have the plastic bag from the Powermatic lathe I just bought. I'm in Cincinnati at the Ohio Valley Woodturners Guild Symposium and will look when I get back on Monday.
Joe
Brad Vietje
Brad Vietje
>Great Joe,
Let me know if it turns up. Otherwise Gil's plastic pockets look pretty darned good!
Safe spinning,
Brad Vietje
Newbury, VT
Joe Herrmann
>Brad:
I found the plastic bag that my lathe cam in and it's yours if you want it. Send me your address and I will mail it out to you tomorrow or Wednesday.
Joe
Rich Egan
>Brad:
Stop by your local furniture store that sells mattresses and see if they will give you one of those clear mattress bags. That should fit with room to spare.
Rich
