Learned The Basics of Using A Bowl Gouge Today
charlie belden
>Thanks to a turning club member's cajoling and offer to show/ teach me the basics of using a bowl gouge I now may begin using the bowl gouge - I bought three years ago - and tried - ONCE.
Turns out using it the intuitive way - is - WRONG! Bevel rubbing then rotating the uphill cutting edge into the down spinning wood gets you a nice catch. But if you rub the bevel and bring just a little bit of the END of the BOTTOM of the cutting edge into contact with the wood . . .
And to see what's cutting and how and where, you almost have to have your chin on the turner's shoulder - something most turners probably find disconcerting if not downright weird.
Were I to want to turn bowls, though they can't be larger than about 9" in diameter, I now have the basics of using my almost unused, very sharp, bowl gouge. I can, and have, turned bowls with a combination of a skew for the outside and the MiniMonster for the inside - but now I have one more tool in the turning arsenal.
Got a turning tool you've had for a while and haven't used yet, or tried once - using it the intuitive but WRONG way - and scared the hell out of yourself?
Have a turning tool you were apprehensive about using and found out how to use it that works for you - and had it become your favorite tool?
Re: Learned The Basics of Using A Bowl Gouge Today
Berger's Jumbo
Mike Jones
>I had a brand newish Berger tool that lived in a drawer for years simply because I didn't know how to use it. I've got a Jumbo Berger now that I use often. With a drilled starter hole, the Berger peels out a hollow form faster and easier than any of my (many) other tools.
Good on any form with fairly straight sides. I'll also start with it and hog out innards until it's time for a swan neck tool.
Good for you Charlie
Paul Zerjay
>I was under the impression you were an "old hand" at all manners in turning. Just goes to show ya how easy it is to get a totally different idea of what is meant over an internet connection.
I am sure your bowl gouge will give you years of enjoyment, just be sure to remember it's not an all purpose gouge. I had forgotten about my spindle gouges for quite some time.
Old Hand? No. Old? Sort of.
charlie belden
>I started turning - on a little UniMat metal lathe in early 2004, five years after getting into woodworking - initially ply stuff then solid wood. So I'm a relative newbie to turning, though I've got a lot of hours in at the JET mini/midi. But I've been drawing and sculpting since I was about four.
In retrospect art in one form or another has been my lifelong avocation, engineering being my working career vocation. So I come at things from both and intuition and analytical. If something interests me I get into it - and study it, looking for WHY as well as HOW.
Engineering training involved both drafting ( french curves, ship curves, highway curves) and math - wthich also involves visualizing curves - or all sorts and geometry - which gets into proportions, conical sections and tangents - the latter important when "blending curves" to produce fair curves. All that stuff makes it easy to spot when an almost "fair curve" isn't quite right, and spot where the discontinuity/blending is off.
From jewelry making using the lost wax casting method, which also was used for doing small sculpture, I've picked up flowing lines. From photography I've picked up In Camera Composition, from drawing and painting - how to get ideas onto paper. From CAD I've learned the drawing equivalent of word processing. From playing with computer graphics and image manipulation I've got another visual equivalent to the word processor.
I've looked at EVERY photo of every piece by every turner on the WOW site, and studied many to look for what makes pieces appealing to me.
And when I say "study" I mean bringing image into a CAD application and scaling things, using a spreadsheet to caclulate proportions and tweeking images to study the effect of changing proportions or just changing a few curves - a little or a lot. And if I can illustrate something I think I've "discovered" that seems important - when I'm done I REALLY understand it.
Inadvertently, I've been preparing for wood turning almost all my life. And now it may be time to start turning some bowls - with a bowl gouge - rather than a skew or a captured system. But at this point in the journey I'm just trying all sorts of things and haven't settled into getting really good at any one thing. Movement's got my attention for now and who knows what will come next.
sure is interesting and fun though!
