Christmas ornament proportions?
Bill Turpin in WNC mountains
>What is the proper proportion of ball height to the bottom finial length? Does the Golden triangle (or some other rule) have any importance here? After studying WC's wonderful ornament collection,it appears that a ratio of anything from 1/1 to 1/6 is OK. Is there a best ratio?
Re: Christmas ornament proportions?
>Bill I don't know. I find the shape of the ball has a lot to do with the length of the finial. Even the shape of the finial. I have not been able to put a number on what works. After I make about 50 I start to get the dimensions right.
Just to throw another question into the mix. How many segments or divisions should the finial have. For example, when I do the golf tee type of icicle I like 3 sections. The odd number just looks right. When I do the ogee or ballister shapes I think 2 sections work best.
bob davis
>like john three seems good for most icicles.i have made hundreds of ornaments and iguess many different kinds of icicles. some people think yhe more segments the better.as you move along you will answer your own question
Dick Coers
>I start with a 6" long, 3/4" dia dowel that I make myself. (3/4 square stock a couple feet on, 4 passes on a router table with a 3/8" roundover bit.) On that I glue a 2" square that is 1 3/4 tall. I locate that 1 1/2" from the top of the dowel. To do that I drill an oversize hole in a 2x4, place the block on the 2x4 with the 3/4" hole over the oversize hole, and tap in the dowel untill it hits the bench. Then everything gets turned and I shoot for an elliptical shape on the sphere, and whatever shape on the finial. I have always made the statement that I can't get an extra quarter for a hollow ornament, so the sphere is solid.
