Collers for hollow forms
Bill Crommett
>What is your preferred method of making collars ? I have tried several ways, but they are all stressful and sometimes drastic.
Bill Crommett
Re: Collars for hollow forms
Brad Vietje
>Hi Bill,
I usually make one-piece hollow forms, which may not help you much, since that usually means a smaller hole and even more stress! Collars are usually a simple inset type, with a wider collar, a step down to match the inner diameter of the opening, and a third diameter, sometimes drilled, not turned, that represents the inner diameter of the final piece. How small you make inner diameter, or "hole" in the collar depends on your design.
Really good instructions and photos in "Woodturning: A Fresh Approach", by Robert Chapman. John Jordan's "Hollow Turning" video shows how to remove, then later re-attach a small opening for a classic bottle form.
If you make a collar from a contrasting wood, you can turn it from one end, either in a scroll chuck or on a glue block, and set it aside to part it off later, when you know the finished size of the HF opening.
-or-
Turn it as above, and part it off, leaving enough wood where it will eventually set down into the HF opening. When the piece is all finished except for the collar, re-mount the collar between centers with a chunk of wood turned to snugly fit the inside of the collar (and with a flat rim to support the collar so it runs true when held between centers), then carefully size the step to fit into the opening. Most people use inside/outside calipers for this, which can save a lot of trail and error.
I find it easiest to drive the piece with a carefully-sized tenon held in the chuck and inserted into the inside of the opening of the collar. The tailstock is brought up to into the eventual "inside" end of the collar to keep the whole business running true. In this orientation, when you get real close to a perfect fit, all you have to do is pull back the tailstock to check the fit. Returning the tail center *should* bring it all back to running true if you need to remove a bit more.
If you want more help, please try posting a photo of the specific problem you are having.
Safe spinning,
Brad Vietje
Newbury, VT
keith zimmerman, Normal IL
>Bill, I generally turn my collars after the hollowing is completed on my hollow form with a tenon to fit the opening size of the hollow form.
With the blank mounted in a chuck, I will turn the outside of the collar to the shape I want, then drill a 1/2" hole through it with a forstner bit. This is because I like small openings in collars, reminiscent of a southwest seed pot.
When turning the underside of the collar, I make sure the surface matches any curve the hollow form may have. This is to ensure a good tight fit with no gaps between the collar and the body of the piece.
The next step is to use calipers to ensure that the tenon is the proper size to fit the opening, and part it off. Since the outside of the collar is done, I just hand sand the bottom side so it is smooth. It is ready to glue on to complete the hollow form.
keithz
Re: And don't use CA glue......
Jamie Donaldson
>..because the wood movements will break the join. Silicone or epoxy is better because it can move a bit as the wood moves.
Re: Collers for hollow forms
Wally Dickerman in Arizona
>Bill, I have 2 ways of doing collars. If the opening is to be fairly large, I true up the dry, roughed out piece and just glue the collar material to the vessel. It now becomes part of the piece and I just proceed to shape the collar.
My other method is similar to what others have said except that I use double faced tape. I did a tutorial on WoW, complete with pics. Go to reviews and search for collar. 8 pics I think.
Wally
Barbara Gill, Remlik VA
>I have not had a problem using the flexible CA (so far).
Re:Barbara- I haven't tried any of ...............
Jamie Donaldson
>....the flexible CA yet, so what viscosities are available? I wouldn't think a thin would be very useful?
Carole Valentine
>I use the Flexible CA as well and have had no problems. As far as viscosity, I believe it is medium.
Bill Crommett
>Thanks to all of you. Now I only have the stress of deciding Which method to try first.
