turners elbow...
turners elbow...
turners elbow...
GaryG in MD
>OK, I know you're not doctors.
Well, maybe some of you are...
Anyway, I've got the dread right-elbow tendinitis.
I know -- don't squeeze the handle so hard.
That lesson has been learned.
If you have had it, what did you have to do to get rid of it?
I tried not turning for a month, and it didn't work. ...Gary
Re: turners elbow...
Sean Troy
>The only thing thats given me relief is a combonation of things and I did get 90% + relief. Cortosone shot in the elbow and wrist brace that fits up to the half way point of your arm before the elbow. there is also a wrap that you can wear just below the elbo. I did all three to be able to turn again. Give it a week after starting this if you go that route. You really need an orthopedic to work with you. Good luck, I know how debilitating the pain can be.
Mike Nelson
>Mine is in my left elbow, I think I really banged it against an imovable object and now instead of an ache or sharp pain I get a burning where the ligiment comes off the elbow. I think it is from too firm a grip on the tool rest.
Braces...
GolfSteve in Calgary
>The braces have worked for me, but I had to religously wear the brace whenever I put stress on the elbow or I re-injured the tendon. Took about two years to heal.
Years ago I had the first clinically ...
Jamie Donaldson
>...diagnosed case of "camera elbow," attributed to cranking my Rolleiflexes and shaking hands. After surgery and PT were of some relief, the best medicine was icing the joint after any contributing activity. The constrictor bands were also used, and I sucked enough ibuprofen to aggravate an ulcer. So try the ice routine, then when it's getting better try alternating heat and ice to enhance the healing, but it won't be better any time soon.
Re: Years ago I had the first clinically ...
Sean Troy
>Jamie is correct. Ice really does help. I knew when mine was returning when a handshake would hurt like heck in the elbow area and below.
Carole Valentine
>Been there, done that! Ice and Advil help in the short term but the only thing that got rid of it completely for me was no turning for about 2 1/2 months. I still have to be careful to keep a very relaxed grip and if I feel it coming back even a bit, it's ice and rest for a few days. Chainsawing contributed to mine as well. Nasty stuff, that tendinitis!
Barry Turner
>I've had the same malady. Mine flairs up when I turn vessels. Apparently, this puts more torque on the elbow. I think several things might help. Hollow smaller vessels. Get a captured hollowing rig. Currently, I am using Kelton hollowers in an 18" Oneway handle. When I turn bowls, I don't seem to have a problem. The only treatment I've had to do is simply rest the elbow for a few days by not turning vessels.
Brad Vietje
Brad Vietje
>Hey Gary,
What sort of turning do you do?
A few years back I had the same problem, from turning hollow forms with too much muscle, and not enough good technique. I laid off turning for a while, took it pretty easy on that arm for a while, and got a stabilized boring bar for hollow forms.
About then I leaned what I was doing wrong, and corrected it. I was gripping the tools too tightly, and not always keeping the rest under the straight part of the tool. In total, I knocked off turning for about 2 months, and came back to it with a relaxed grip and better technique. After a few months it was much better, and has never come back.
I still don't use the boring bar that much, but it's good to have one for bigger projects.
Good luck and safe spinning,
Brad Vietje
Newbury, VT
Bernie Weishapl
>I had to stop turning for a couple of months with mine. Ice and Tylenol Extra strength seem to work best for me. I wear the brace and now use a captured hollowing unit. Haven't had much trouble since. Bowls, ornaments, etc. didn't seem to bother. Maybe I was using a lighter grip.
charlie belden
>All the tendons (almost called them tenons) from your fingers and wrist connect almost at a point on your forearm at the elbow. If you can distribute the forces over your whole forearm the pressure at that POINT goes down - to a level that doesn't cause as much irriation, swelling and resulting pain. A "shock band" around your forearm will do that distribution. They sell them at most drug stores, velcro band, some with a little plastic "accupressure" bumpt that's supposed to help.
For any repetative motion problem, icing BEFORE exercising shrinks blood vessels so when they expand from muscle use, they don't get that much larger than normal - rather than swelling up larger than normal.
This is the info I was given when I had both elbow and shoulder inflammation related problems. Anti inflammatories were also recommended - if you don't have ulcers or similar stomach problems.
Oh, and that
"It only hurts when I do THIS."
STOP doing THAT!
is true. See if you can figure out what's initiating
the problem and STOP doing THAT! A small change may eliminate the source of the problem - bigger diameter handles, lighter grip, padded palm fingerless gloves, different stance - and if all else fails, a captured system.
Scott in SoCal
>I sometimes have problems with my right hand and wrist, and I've found that having a larger diameter handle (bigger wood or wrapped with foam/grip/whatnot) lets me use a lighter grip and still feel comfortable. It seems to let my hand engage more muscles and tendons than when I'm wrapped around a small tail like on a Sorby tool.
Curly Smith
>Try the exercises for "shoulder tendonitis". If the tendon is inflamed in your elbow there's a good chance that it's also inflamed in your shoulder and your shoulder has very poor blood circulation. The exercises will strengthen the shoulder muscles, which is a good idea for those times when your elbow is away from your body and putting stress on the shoulder, and will increase blood flow to aide in healing.
robo hippy
>I was getting a sharp pain for a while, till I remembered to remove the tail stock.
But seriously, I hold my gouge with my hand near the steel, and have it under my fore arm all the way to the elbow. Never had any problems.
robo hippy
well, that touched a nerve... ;-)
GaryG in MD
>Thank you Sean, Steve, Mike, Jamie, Carole, Barry, Brad, Bernie, Charlie, Scott, Curly, and robo...
I have read all your comments carefully and made a "list" of all the great suggestions. ...now if making the list was all I had to do, it would be nice, but...
I always said I would only turn alone so I wouldn't end up doing anything due to peer pressure. I did it that way for years with no problem (relaxed and frequent breaks). Then I accepted an invitation to turn with a friend. We had a lot of fun, but I had to race to finish a piece, and I must have been stressed because he noted the tension in my arm at the time. The next day, I had it.
That was three months ago. I've been using ibuprophen to keep it under control, but I obviously need to take the next steps. Your experiences have helped me understand what I'm up against and how hard it's going to be to get rid of it. I'm definitely aware of my grip now. It's made a better turner of me, but that's a high price to pay. From now on, any hollowing will be with an outrigger on the angled tools.
Time for action. Thanks to you all for your good comments. ...Gary
Stupid Question Gary...
Scott Burr in Ben Lomond CA
>Can you switch hands, arms? Go south paw? Might be so hard as it seems... I'd give it a try.
Re: well, that touched a nerve... ;-)
>Gary I didn't have severe pain in my elbow but it was hurting a lot. I started a new weight lifting routine to see if I could ease the pain and it worked.
I use a light weight (10 to 12 lbs) I bend my arm 90 degrees and hold the weight against my stomach. Then I rotate it out away from my body as far as it will go keeping my forearm parallel to the floor. I do 3 sets of 10 with each arm. Mostly that gives my left arm a chance to rest which is the one that hurt.
Then with my arm in the same position but the forearm pointed straight out I rotate the weight clockwise and counter clockwise. I do 3 sets of 10 of these.
Then I do light weight curls. I use about 1/3 of my normal weight and do sets of 20.
That solved both my mild carpel tunnel and my hurting elbow.
Brad Vietje
Re: Turning Bowls
Brad Vietje
>Bernie,
Bowls *did* bother me, when I had it. I learned quite quickly not to grip the tools very tightly (with better technique, sharpening and control I didn't need to, so this just took more experience on my part), but I was pushing the tool into the wood too hard.
Not "pushing" so much -- the cut was still in decent control-- but trying to hog out the wood too fast. Pushing the arm forward hurt not only my elbow, but aggravated an old rotator cuff injury to the shoulder. In those days, gripping a door knob was OK, but pushing the door open could make me wince, especially if the door hit anything!
For rapid rough-turning of green wood, I learned to lever the tool around a fixed point on the toolrest -- my left hand became the pivot, or fulcrum, and I could make pretty aggressive cuts by moving my body or my right arm, and not "pushing" forward so much.
That, and some "Vitamin-I", or "I-Be-Broken" and a rest from turning can really help!
Safe spinning,
Brad Vietje
Newbury, VT (with snow comin' down...)
Ed in Sptbg.
>After I raised the spindle centerline on my DVR, I started having pain in my right elbow. I put down a rubber mat on a 1/2" piece of plywood to stand on. After that, no more elbow pain.
Mousing around
Jorge Castaneda~Downeast Maine
>Gary,
I get it now and then when hollowing, I noticed that it get even worst if I spend time at the computer mousing around, the clicking he mouse aggravates my elbow, there is some connection there, so another consideration.
Get well soon
Jorge
Dick Hines
Dick Hines
>I don't have trouble with my elbo but my thumb on my left hand will give me a fit after working on samll pieces for a long time. I tend to use my thumb to guide the tool.
Keith Tompkins
Keith Tompkins
>Gary, I have lyme disease, which flares up whenever it wants. Fish oil pills help relieve pain in my joints..really works.
Re: Turning Bowls
GaryG in MD
>Brad, Funny you should mention doors -- I had to ask my wife to push the door open today after I unlocked it. Well, I've received a lot of good ideas and info here, so now it's time to put it all into an action plan. ...GG
GaryG in MD
>This is very good advice. Thanks John. I suspected that some proper exercise would be good. I was just about to look it up. I've got the weights and will give it a try. ...GG
Re: Mousing around
GaryG in MD
>Jorge, Yes, that can be a problem too. With me, it affects my shoulder (where I have another, old injury). So I do the mouse with my left hand. ...GG
