Handles and Grips
charlie belden
>There�s been a great deal of innovation in the design of turning tools, especially hollowing tools - with almost all of that innovation focused on the cutting end of the tool, and for want of a better word, the shank. Initially it was adapting existing, traditional turning tools, to either do something they were designed to do - but do better/faster/easier - or do something they weren�t originally designed to do.
When the idea of hollow forms came along all sorts of new grinds were tried and shanks got bent, crooked and goosenecked. And at the cutting edge, HSS was replaced by harder steels, then carbide. Articulated ends were used and �depth of cut limiters� were added.
Cuts that previously either couldn�t be done, or could only be done with a �traditional� tool, ground and sharpened just right, and used in a specific way that required a steep learning curve - became possible, even easy - for anyone who could BUY the tool (and of course spend some time learning to use it - that time being considerably less than that required by earlier tools).
We�re accustomed to turning tool handles being round - that�s the way handled tools come right? And the tool makers know what they�re doing so they SHOULD BE round. Turned on a lathe things are round so . . .
Then �pistol grip� handles came on the scene, with or without the forearm �cuff� and auxiliary handles were added - at 90s to the normal handle - all in an attempt to resist �catch� rotation of the tool.
What has been somewhat neglected in the innovation area is The Handle. With the exception of the Michelson triangular handle, as far as I know, not much has been done to provide visual or tactile indicators of where the cutting edge is relative to �visual up� - ie cutting tip orientation. If my thumb is up - the cutting edge must be . . . Knowing the cutter orientation is kind of important when hollowiing through smaller openings - or undercutting an overhanging rim.
Of course, one can always scribe a line on any traditional handle, or drill a hole and inlay a small circle of a contrasting wood to identify �up�.
Which gets us to - How do YOU grip the handle of your turning tool(s)?
Do you use a single grip for ALL handled tools or do you use a specific grip for a specific tool?
If so, why does one tool require one grip and another tool require a different grip?
Do you wrap your thumb around the handle or keep it in line with the shank of the tool?
Do you always grip at the fat part of the tool or do you sometimes grip back in the thinner area?
Aside from the longer lever arm and therefore amplification of movement at the cutting tip of the Grip All The Way Back grip, why not grip at the rear of the handle?
This may seem like a subtle, minor thing, but most tip control starts at the handle - and how you�re gripping it.
