Remedies for removing a stuck lid
Paul Zerjay
>Short of prying off a stuck lid, does anyone know of a way to remove one? I have one that has really nowhere to grip, and has a finial that I would rather not break off either. TIA
Paul Zerjay
Re: Remedies for removing a stuck lid
Russ Fairfield
>You have discovered the problem with making lids with a snap-fit.
Heat it in the oven at lowest setting, not to exceed 130F, which is at the point of being too hot to touch and hold with your fingers. If it is a stuck finish, the heat will soften it. If the wood is swollen from moisture, the heat should shrink it again. If there is a tight seal, the heated air inside may pop it as it expands.
If the wood has shrunk because it is too dry, put a pan of water in the oven with it for an hour.
One or the other will return it back to where it was when the lid fit.
GalenV in Iowa
>Paul,
I've had two small boxes where the lids were stuck. I put them in the freezer for the day. When very cold I used the heat of my hand to warm the top faster than the bottom. The lids expanded and let loose of the box. It still took some force to pop it off but there was no other way I could think of to remove the top.
If your top fits inside a hollow form it may not work.
Galen
>If you have enough room to wrap an electrical wire around it you might be able to twist it off. use a wire that has a lot of friction. Wrap the wire around so you have 2 ends together. Grab these and twist. It will work similar to the way an oil filter wrench works. I've had great success with this on all sorts of things, especially getting stuck filters off of camera lenses.
Barbara Gill, Remlik VA
>The time that happened to me I stuck it in the freezer for about an hour.
Pic of the piece
Paul Zerjay
>I put the piece in the freezer immediately after my original post, so we'll see what happens. If that doesn't work, I'm gonna try the oven method. do you think that the glue joints will be affected by the heat? Titebond
Wow! That's a beauty
Molly Winton
Freeze it
Jorge Castaneda~Downeast Maine
>Paul,
A while back I had a small box with same problem, our friend Joaz Hill sggested freezing it, and it did work. Give it a try.
Jorge
Woo Hoo
Paul Zerjay
>I had it in the freezer for about 1-1/2 hrs, pulled it out and still tighter than a well diggers you know what. So I immediately nuked it for 45 seconds on high, and with a little jostling, it came off. Thank you all for the replies.
Thanks Molly
Paul Zerjay
Cyril Griesbach
>Beautiful piece, Paul.
Re: Woo Hoo
David Belser
>Congrats on getting it unstuck, as others have said it's a beautiful piece.
So now the question is how to make it not stick? I'm very curious as I have a 1 1/4" sphere box that is just a little too tight.
- Dave
Re: Woo Hoo
>David, try light sanding with 600 grit.
Should have entered the "Elegant Forms" contest
>That is a lovely composition, Paul. Congratulations. I'm glad you were able to get the lid off.
Cheers,
