Lathe duplicator any info would help
Wayne Carson
>Looking at a duplicator for my lathe anybody have any experience with brand. Made by Rand RAND WOOD LATHE DUPLICATOR/COPYING DEVICE
Re: Lathe duplicator any info would help
Nope- only the Vega *LINK*
>I've been playing with the pro model. It works better than I thought a duplicator would. Not as clean a finish as I get but much faster at duplicating and a decent enough finish for most applications. A little sanding will take care the minor tool marks.
You can mount this one on the back side of the lathe. Then you can go around to the normal side, install the tool rest and clean up details that either can't be cut with the cutter used or need a little cleaning up.
If I did very much of this duplicating thing it would pay for itself pretty quickly in time saved.
http://www.vegawoodworking.com/
Re: Nope- only the Vega
JohnKyler
>I would not buy any except the Vega. I have made spindles with it with fair-good results. I have found that on paint grade spindles they can whip enough to cause too much cleanup work. I can turn smaller spindles faster using traditional ways. If you are in the Colorado area you can come and get my Vega and try it. It no longer fits on the newer lathe (need the brackets for PM4224) but will work on other large lathes.
As for the Rand and cheaper ones you get what you pay for.
And Vega is USA made!
John
>You can get a steady rest to go with the Vega to stop the spindle whip. I agree in part that I can turn a spindle just as fast but not exact duplicates. Close enough for most work but If I want an exact copy it takes me quite a bit longer.
I'm still new with the duplicator and learning what it can and can't do but it does make an exact duplicate with only a little clean up. What I found in my initial tests was I would turn them on the duplicator and then put the parts on another lathe and clean up any tool marks and make the V's deeper with my skew or spindle gouge. The time saved was not huge but they were pretty much exact duplicates.
