>I have a light I salvaged from a dentist's office. I mounted it to the ceiling above my lathe and can swing it around on the articulated arm to shine on my turnings. It's probably twenty years old and does not have the LED bulbs that I see in some of them now. The light gets HOT. The reflective coating as cooked off the reflector. I called the company and was astounded to learn a new bulb was $80 and the reflector was $600. I said No, not the whole light, just he reflector. Yep, $600. So I asked if I could recoat it. The guy said "I can't recommend it." I pressed a little and he said all I CAN say is I can't recommend it.
So, the question is, would you take a shot at it? What would you use?
I also asked what the entire light would cost and the answer was that they no longer make this model but it sold for $3600.
>Barry see if you can buy some Chrome or aluminum paint from the automotive store. They may have high heat versions. YOu could have it rechromed. It would not be cheap but might be cheaper than $600.
I've been looking at the new compact Flourescent lights but they don't come in high wattage unless you get into a really physically large.
>Most companies, in this day and age of barracuda attorneys, will try to not do anything which will subject them to liability issues. Also, they wouldn't stay in business too long if they told every customer how to do cheap fixes. While I have never tried anything like this, I would think with a little time and effort, that using MicroMesh sanding strips and polishing compounds, the metal could be polished so that it wouldn't need any coating. This "phree" advice is really worthless if you don't have the time. I would try to find a company that has the capability of recoating and see what they think.
>The reflector is a piece of Glass or something like Pyrex. Pretty thick and heavy. As the coating falls off the light goes out the rear, instead of being reflected into the work. I guess this would be like resilvering a mirror, but one that can take some heat.
Studio Xenon mirrors are silvered and coated with a high temperature backing so sounds like the condition you have. You may find someone that can repair these and rework you light. Cost????
There is colored high temperature paints used for car headers and even disc brake calipers that would probably be able to be applied to the glass and be somewhat reflective, but not like a silvered mirror. At least it would prevent light from going through the chipped areas.
>It can be re-silvered. I have a friend here who is a glass blower who has done a lot of silvering. I looked into it. It's not hard but has very hazardous materials. Check with your local glass companies who carry mirrors. They may have someone who can do it for you.
You might be able to find a replacement mirror on eBay --> I've seen them listed. Search under 'dental lights' in the Business and Industrial category - or under the name of the manufacturer. You may find the model you have in a non-working unit and get a replacement reflector at a much cheaper price than $ 600!
And yes, if you go to the company for the replacement bulb, you will undoubtedly pay a premium price for a new bulb. I assume you have a ceiling mount (and not a modified post mount) lamp - these should have standard lamps (likely halogen, so just look for the lamp number and confirm the wattage and voltage before you search. I have gotten high intensity projector bulbs (halogen) on eBay for $7.00 and $ 10.00; the dental lamp I have uses a standard halogen bulb, so don't give up on looking for them at a bargain price. Just stay away from the manufacturer as a replacement parts source unless absolutely necessary.
I agree with John's advice in going to a glass/mirror store and seeing if they can re-silver the mirror for you. Unfortunately, I think most of these dental reflectors are first-surface mirrors, which require a substantially thicker coating, which will likely increase the repair costs.
>Barry, I use two dental lights for my turning. One recently burned out and after checking with my dentist he suggested I check with a company named bulbconnection.com for new bulbs. I ordered two of these very expensive bulbs for a total of $8.95 each. Check them out and I'd bet they have your bulb as well and will save you some money! Good luck!
>Thanks, I actually don't need a bulb. My is working, right up to finishing this sentence. I will squirrel the address away until I do. Or maybe I will buy a spare, just to keep Murphy at bay.
Also, I have another light. Thought about selling it, but right now I am keeping it for spare parts. I was so astounded at the price of the parts, I couldn't figure out what a fair price would be.
This thing throws a tremendous amount of light, even with a damaged reflector.
