How do you sand?
How do you sand?
How do you sand?
Claudia Hayward
>I was sanding a bowl yesterday and started wondering how other people do it. Most of my work is with bigleaf maple. I generally start with 60 (sometimes) or 80 grit; occasionally I'll start with 100. On the outside I'll sand handheld with the lathe turning slowly. On the inside I start with the lathe stopped and a sanding disc on my electric drill. After I get all the inevitable tool marks (I always have tool marks no matter how hard I try and I've been doing bowls for many years) I move on to my random orbit with the
same grit that I used on the sanding disc. At this point the lathe is stopped. I get rid of all those ugly circular swirls then work my way up with the ROS through 120, 150, 180, 240 and 320. I still have difficulty removing the mini swirls left by the orbital motion of the ROS since each successive grit seems to leave its own marks.
After doing many, many bowls I find I'm still refining my technique!
How do you get the perfect sanding job?
Re: How do you sand?
Peter Charles Fagg (UK)
>I cannot claim to have perfected sanding with an electric drill but it works for me!
99% of the time I start with 80 grit, then 180, 240, 400, only in exceptional circumstances (i.e. hard exotics) I use 1200 or even 1800.
All my sanding is at a reduced lathe speed on the side opposite to me in the bottom quarter so that I can see inside the bowl/platter. I try to use the whole surface of a 2" Velcro disc most of the time otherwise it tends to waste discs.
I have been doing it this way for longer than I care to remember and as I said at the outset, it works for me, no doubt others will disagree with my methods!
Just keep trying, it does get boring sometimes but more often than not the end result is worth the hassle!
Regards, Peter.
Re: How do you sand? *LINK*
Greg Haugen
>Here's a Youtube video from Mike Mahoney. This is how I sand bowls. I also sand to 400, mist the bowl, after it dries sand with 400 again. All of the bowls I make are made to be used. By misting with water and re-sanding with 400, I'm eliminating the "raised grain" when the bowl gets washed.
On his site there's a file "finishing utility bowls" and there's a lot of info there as well.
http://bowlmakerinc.com/resources.html
Hope that helps.
Greg
Mahoney's Youtube
robo hippy
>First step for me is to soak my green turned to final thickness bowls in LDD (liquid dishwashing detergent, and water). After drying, I sand. I have my lathe adjusted (3 phase Robust) so it will go down to almost 0 rpm. Most other 3 phase lathes are now factory set to turn off at 50 rpm, older PM A models would go down to zero. On a warped bowl, you can't keep your hand on the wood at speeds of over about 20 rpm. I power sand with an angle drill. I have a piece of cork under the trigger to keep the speed down to about half, or 600 rpm or so. This really is more efficient than the higher pad speeds. My starting grit is decided by which will take longer, sanding out the tool marks with 80 grit, or sanding out the 80 grit marks with the 120 grit. Some times it is faster to start with 120, even if Mike always starts at 80 grit. I will use a firm pad from Vinces WoodNWonders with the quarter round profile on the outside edge. 120 on a firm pad will sand faster than 80 on a soft pad, and the rounded edge fits into the inside of a bowl much better than the square edged pad. I also prefer the oversized discs because they over lap the sides of the interface pads so you don't get swirl marks from the disc. Tried some 'wave discs once, and didn't like them. On the outside, most of the time I will start the lathe as slow as it will go and do a rough sanding to see if there are problem areas that will need sanding with the lathe turned off. I will do the same thing on the inside as well. Most of the time on the inside especially, I will hand spin the bowl for checking the inside as I sand. Makes it easier to see that I am getting all my marks out. At some point on at least every other grit, I will hand rotate the bowl as I sand to make sure I am getting out all tool and sanding marks. I don't ever leave a small blemish, figuring that I can finish it on the next higher grit. That never works. I will switch to a soft pad some where around 220 or 320. I stop at 400. 320 grit can leave sanding marks that are visible to the human eye. 400 can also, but it is much more difficult to see. If you stop at 320, I would suggest to hand sand for a few revolutions. The straight in line scratches look more natural than the swirl marks. I finish with Mikes walnut oil, applied very liberally with one of the grey synthetic steel wool pads. This will buff out most sanding swirls that are left. Of course, I toss dull abrasives quickly. I do keep the eraser stick handy to get a little extra out of the discs, but some times you just have to toss it. I prefer the film backed discs. Mostly it is because they are more flexable and stronger, where the stiffer paper discs will actually leave swirl marks and are more prone to tearing. I have never been tempted to use a r.o. sander. Most are pneumatic, and will keep a compressor running non stop. Also, haven't felt the need for one. Having a good light helps more than you can imagine if you haven't discovered this yet. One of the multispectrum lights (Ott, or Blue Max, all the sewers know about them) does almost as much good as taking the piece out into the sun light.
A sanding motto I have come up with is, "Sand till you think you have all the marks out, then give it quick once over".
robo hippy
Don at Central Illinois
>You need to check yesterday post. I think Steve Kubian said he was using his tools to get to about 2000 grit and didn't need sand paper. I think I'm going to have him give me lessons. Wouldn't it be nice not to have to use sandpaper?
Barry Turner
>I hear a lot of people say they don't like to sand, but it is a very important part of the turning process. An improperly sanded piece is never going to look good. It's important not to over sand and thus obliterate sharp edges and other details. I power sand all of my bowls. Most of the time I use 2" hook & loop disks on a soft mandrel. The drill I use is an old Panasonic 9.6 volt cordless drill. Top speed is 1500 rpm which is usually the speed I use. The bowl is kept turning in the lathe at 50 to 100 rpm. I sand against the lathe's rotation in both directions, reversing both the drill and lathe. I power sand a bowl inside and outside. The grit I start with is usually 100 depending on the surface of the bowl. I sometimes start with 50 or 80-grit, less often with 120. I usually power sand through 180 or 220, then hand sand with only the lathe running to about 320 or 400 grit. I use a 3M gray non-woven to pad the sandpaper, keeps the fingers cool. I sometimes wet the bowl and raise the grain when sanding with the final grit. When dry, sand again with the final grit. I have never felt the need to use a random orbit sander and seldom sand with the lathe stopped. I hope this helps. It works for me.
Mike Jones in Redding, Ca.
>For power sanding, I have come use a Makita right-angle cordless. It is very slow and the long shape allows for good two-handed operation. Both of these features give me excellent control.
I use far more sheet paper than discs anymore and hand-sand a lot. The ability to change directions and sand with the grain, to cup a half-sheet trifolded, or cut to fit the fingers, seems to get me done quicker than power sanding in many instances.
Although of no realistic use anymore, I think that hand sanding all these years has probably helped me develop a pretty quick right-cross.
