ADVERTISE HERE - FREE TRIAL
A lesson learned
A lesson learned
A lesson learned
Paul Zerjay
>Do you seal the inside of your HF's before reversing on a vac chuck? I did, but stopped doing it, thinking it was a waste. But I am thinking that I will go back to doing it in the future. At least on dark wood. I had a Walnut HF and I reversed it on the vac chuck, turned off the tenon, and proceeded to sand. The vacuum seemed to pull the dust from sanding into the grain of the wood and made a visible lighter spot. I think that if the inside was sealed, it would not have happened. Sloshing finish around the inside of a HF always seemed a waste of time, and made a mess. Also it's a guessing game as to how much finish to dump in there. I always seemed to either get too much, or just exactly not enough. If you dump too much in there, all the extra is wasted. So I just quit doing it. Now I believe I'll have to rethink my decision. Anyone ever had this happen?
Re: A lesson learned
Couldn't you blow out the dust?
Re:Problems like this can often be .......
Jamie Donaldson
>... remedied by placing a piece of Saran wrap in the general vacuum area inside the turning. Works well for open grained wood and Ambrosia maple holes.
Re: Couldn't you blow out the dust?
Stuart Johnson
>I'm not certain but I think the vacuum pulls the dust through. I had a couple Cherry platters that had rings that matched the vacuum chuck. I'll certainly try pre finishing or at least sealing when I try platters again.
Paul Zerjay
>Jamie I've used shrink wrap on the outside of a vessel that has inclusions, but I'm not following you on how shrink wrap can be held in place on the inside. To my understanding, the wood must be between the vacuum and the shrink wrap. What your describing is putting the shrink wrap between the wood and vacuum. All that's gonna do is suck the shrink wrap into the drum chuck. I'm obviously missing something.
Steve Kubien
I've always been told....
Steve Kubien
>....to finish the inside/underside of a piece the same as the outside/top. The idea being that the wood inside and outside will breathe at about the same rate. Now, I'm not going as far as putting 6 coats or wipe-on poly (or lacquer or whatever) on the inside of a piece like some do on the outside, but I can see putting 1 or 2 coats inside.
No idea on the dust and vaccum chucking as I don't have a vac chuck and, of course, the finish I get off my tools is the equivalent of sanding to 20000 grit. :)
Steve
-2 more sleeps until Disney!
Re:I have placed Saran or shrink wrap .......
Jamie Donaldson
>... on the inside of a vessel and positioned it to cover the bottom area where the vacuum seal would hold it in place, thus creating a seal. This also reduces the occasional vacuum ring mark that appears when moisture is pulled from only the seal area.
Re: I've always been told....
Bill Howatt
>... "the finish I get off my tools is the equivalent of sanding to 20000 grit. :)
Steve"
Steve, you are already in Fantasy Land!
Bill
Steve Kubien
Yes bill but...
Steve Kubien
>...it is a happy place. And warm and cozy and full of fluffy bunnies and pretty flowers.
Dick Hines
Dick Hines
>I use oil finish on all my bowls and hollow forms. I use the oil on the inside of the hollow forms. I just dump waht I think it will take and slush it around. Then when the inside is covered I turn the hollow form upside dowm over a small plastic bowl and let the oil drain out. If you blow the dust out before you use the finish it can be used again.
