Veritas - Innovation in Tools
Cane Tip Question
Cane Tip Question
Cane Tip Question
Scott Greaves in Blackfoot Idaho
>I have this nice long blank of Maccassar Ebony that has bee whispering to me lately, and I think it will soon become a cane. I have some of the brass handles from Rockler, so will use one of those. But I don't know what to use for the tip. The most useful would be one of those big rubber tips that go on over the whole end, but they are seriously unattractive. Lately I've been thinking about using a nice brass ferrule, but those are not all that easy to source. I would love to have some suggestions of not only what to us but where I might buy it.
Thanks in advance!
Scott.
Re: Cane Tip Question
Jesper, Denmark
Jesper, Denmark
>Your local hardware store has a selection of different cane tips in stock.
They may be on the utilitarian side of style, so is this cane for use or show?
>Hi Jesper!
For now it is for show. I don't need a cane and neither does anyone in my family. I am going to size it for myself (just in case). But mostly I want to go through the process and write a decent article on the subject.
I turned a nice cane for my Dad a few years ago, out of Afzelia xylay. I bought an antique handle off of Ebay, but I didn't really have anything good for the tip. My Dad had me put one of those big rubber tips on, and he used it every day until the antique handle broke off. I still have the shaft of that cane and I may try to re-do it with a new handle and tip. My Dad's in an electric wheelchair now (which he uses to terrorize the staff at the Veteran's Home!), so he won't need it, and I can cut it down for somebody shorter.
I have been turning these as a single shaft, without the join in the center. Rockler sells a hardware kit that includes a tip and a join, but I hate to buy the whole kit just for the tip.
Thanks!
Scott.
Ron
>your can try Treeline in Provo, Utah. They have the type of tips I think you are looking for.
Re: Cane Tip Question *LINK*
Philip Morris
>Scott,
Treeline USA carries what you are looking for. I know that you said you already have handles, but they carry some really cool harness hames (brass and chrome) that would make nice handles.
Cane Tips
Lee Valley has them
Norm Smith
Russ Fairfield
>That big cane tip that Craft Supplies sells may not be pretty, but it sure is serviceable. The spike under the removeable rubber tip is good for dirt trails.
Dennis in Southern Oregon
Dennis In Southern Oregon
>Scott, you might consider turning your own tip using a brass compression nut from your friendly plumbing supply store. These are inexpensive and come in several sizes. Brass turns fairly easily and can be sanded and polished. One advantage is that the compression nuts are threaded inside, so if you size the tenon of your cane end properly, you can thread the tip onto the cane. To avoid marring the finished tip, thread it onto the cane before finishing the tip. Compression nuts are also good for tool ferrules.
Dennis
Lan Brady
>Scott,
I have only made 2 canes. I use the rubber tips. But I go to the Home Health Care Store. They have tips that are 3/4" instead of the chair size 1-1/4" that is most common.
Another suggestion, and I dont know why it works but it does. When inserting the cane in the tip, I place a metal washer in the tip. It adds life to the joint.
Good Luck, Lan
>Thanks Dennis! I think I might give this a try. The "turn it yourself" aspect appeals to me.
Scott.
>Thanks everybody! I just put together an order to Treeline. I ordered a couple of different ones and will see which I like best. I will post a picture eventually (those who know me realize this won't be soon!) to let you know how it turned out! I appreciate all the input!
Scott.
