Turning Gobblets
Turning Gobblets
Turning Gobblets
Ponch
>I would like to try my hand at turning long stem gobblets. I think I have the right idea of turning the top first, then hollowing and sanding,before starting the stem. after the stem, do I turn the base, and part it? Could someone help me with these steps? Thanks
Re: Turning Gobblets
>That's what I do. I turn most of the outside of the goblet top leaving the stem and full thickness with just a little taper to let me do all but the last 3/4" of the bowl bottom. Then I hollow the inside.
After that I go back and clean up the outside bottom and first inch or so of the stem. Then I work my way down the stem thinning as I go.
If it's a really long thin stem I support the goblet with my tailstock using a loose piece of cloth rubberbanded around the live center. I don't want it rotating or putting any pressure on the goblet I just want it to stop vibrating and wobbling off center which could break the stem.
After I have the stem and top of the foot shaped I use a parting tool to cut down to fairly small tenon. Then I use the toe of the skew to clean up the bottom and make it concave. If I do it carefully and the bowl is supported well enough with the tailstock I can cut it off completely with the skew and be done with it.
I forgot to say, I sand each section as I go.
Bob Edwards
>John is spot on as usual. I mite add that I use a cupped live center
(without the center pin) and a tennis ball to secure the bowl of the goblet while I work my way down the stem. Lite pressure is key here as too much will cause the thin stem to whip and vibrate. On a long, thin stem a spindle steady is advisable.
>I tried the tennis ball thing, in fact I still have it. I found I needed a really really light support so I have use all sorts of jury rigged things from wadded up paper towels to cotton wrapped around the live center.
For really long thin pieces I use a string steady. If your not familiar with those they are a C shaped piece of wood that wraps around the spindle. There are 4 screws in the C and you wrap string around these in an X pattern with the stem in the center of the X. It's amazing how well this works.
Re:A tennis ball is too big and....
Jamie Donaldson
>...heavy for most of the goblets I turn, and a nerf ball from a toy store is my cup steady secret device. It is both light and stiff, and the tailstock point needs very little pressure to keep the cup of the goblet steady while working down the stem.
Re: And don't forget that the speed....
Jamie Donaldson
>...should be controlled by ramping up and down gradually, rather than a quick ON/OFF which can twist and break the stem due to bearing drag in the tailstock.
Steven Antonucci
I was just going to say that!
steve antonucci
>I did a demo on a Oneway, and the controlled rampdown feature twisted the head off with 1/8" left on the foot to cut. I now do them as I've seen Jimmy Clewes do it- unsupported at the tailstock, and it's not as hard as you'd think.
I made two 8" goblets at the Peters Valley Craft show this past weekend in about 15 minutes each.
Steve
