>I'm in the market for a new air hose for my shop. For maximum flexibility and durability, do I need to stick with a traditional red rubber air hose like the one I had or go to one of the newer plastic ones? I think they are polyurethane or some other plastic.
>Like Pete, I use a high quality yellow plastic coil placed overhead, and wouldn't use anything else. I save the rubber hose for my heavy duty compressor in my garage. Plastic stiffness is not a problem in the cold, but who would want to work in an totally unheated shop in the winter?
I have to disagree with those that suggest using a rubber hose.
In both warm and especially in very cold weather, nothing has worked better for me than polyurethane air hose. I have several lengths (one 25 ft., and two 50 ft. lengths), as well as one coiled 'blue' hose that I use at the lathe, all made under the trade name "Flexeel". These hoses remain supple and very flexible in cold weather, and are rated to at lest 175 psi. They have integral 1/4" NPT male fittings, and strain relievers at each end. They are worth the money, and in my opinion outperform standard rubber air hoses.
>I have a slinky hose in my shop. Shop is so small, it's all I need. One winter I was working in the cold so I brought in a temporary heater to knock the shill off until the little electric heater could catch up. The Propane heater got parked under the slinky hose. The heat from it caused the hose to soften and get and aneurysm and burst.
>Sorry for the delayed response, I have the blue color Flexeel hose and it is great, flexible and light to move around. I know we have it in 25, 50, 100 foot lengths. I know it's available all over the place.
>Thanks. I came across that brand name as being superior in some of my research. When I work in my shop, it's normally 60+ degrees, but my air hose lays on a cold concrete floor. I was afraid that could be a problem with a PVC of poly hose, but maybe not. I also read somewhere that polyurethane hoses could be somewhat "sticky". Have you found that to be a problem? I have a 25+ year old red rubber hose that has worked very well, but it's heavy. I don't want to buy another rubber if there is something out there better. Thanks.
