Niles stopper question
keith zimmerman, Normal, IL
>For those that turn bottlestoppers using Ruth Niles' stoppers, I have a couple of question to ask.
I turned several stoppers this past weekend while demonstrating woodturning at a local festival and was having some difficulty in the process. I use Ruth's #301 threaded stoppers and always tap the threads before mounting in the mandrel.
The issue I was having was, while using the mandrel she sells, which is designed to cut threads while screwing it on the threads were stripping out rather than being cut. I tried several different drill bits (7mm, 8mm, 23/64), but none of these sizes worked any better than the other. I finally used the 23/64 and hand-threaded each blank before mounting it on a different mandrel.
I talked to Ruth about the mandrel and she shared this:
"Since we are working with a "live" medium (so to speak), you are going to run into various species that the threading/tap on the mandrel might be either too loose or too tight. I'm hearing both. The only answer is to know which wood is going to need an 11/32", 9mm, or 23/64" hole tapped. If the wood you are using is not holding the threads, after you tap it, put some thin CA into the hole. I'm told that works the best, then the mandrel will thread nicely to turn the stopper."
Is anyone having problems when tapping stopper blanks with her mandrel? If so, how do you get past it?
Thanks in advance.
keithz
Re: Niles stopper question
Jeff Willaford
>I've not encountered any problems but always tap with a light touch and follow with a few drops of thin CA on the threads. After the CA drys I remount the block on Ruth's mandrel and go. Then I've only turned a couple dozen stoppers so maybe my time is coming.
>Keith I use the non threaded Niles stoppers to I can't speak for her product. However I have tapped a ton of holes of all size into all kinds of woods over the years. I have found what she says to be true. You may have to drill different sized holes for correct tapping in different woods. Anytime I tap into wood I soak the hole with thin CA and then run the tap in again.
Some softer woods just don't want to tap very deep and some hard woods want to chip. You just gotta try different drill bits to see if they work. I usually start with the drill size recommened for tapping metal unless it's a soft wood. Then I might try one size smaller drill.
Steve in NC
>I initially had problems with stripping threads. I now do the following: I cut the blank a bit long and mount it in a chuck. I rough turn the stopper with the bottom towards the tailstock. After I get it close to shape, I use the tailstock to drill the hole. I then put Ruth's mandrel in the tailstock and use it to tap threads in the blank (this allows perfect alignment). I then remove the mandrel, part off the stopper, and put a couple of drops of CA on the threads. I then mount the mandrel in the headstock, and thread the stopper on the mandrel and finish turning it. Using this process, the threads on the blank are really only holding the stopper for final turning and sanding.
To save time, I turn and tap several blanks at a time before moving the mandrel to the headstock. Hope this helps.
Steve
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>My solution was to put a few drops of CA glue in the drilled hole BEFORE threading it.
D. Hansen
>I found that my holes needed to be a bit longer than the threads. I also started running the tail stock with a non pointed tail in it. I use that to force the stopper against Ruth's mandrel. that way even if the threads strip a bit the tail-stock hold the piece until I get it formed then I part off and usually don't have a problem with the last finishing phase.
Don in central washington
GalenV in Iowa
>I turned stoppers before I knew of the Niles stoppers. Like has been noted you may have to use a differnt tap drill for some woods. If I have a scrap piece I test drill then note the wood and drill size on the scrap and save it as a reference. I found it much safer to tap the wood rather than let the mandrel cut the threads as a normal step.
For the times I screw up I use it for the opportunity to tap the other end and cover the first hole with a madalion or coin.
Galen
Texian
>Same drill size as used for metal and tap. Screw onto mandrel made from 3/8-16 bolt and turn the "topper" and finish it. Sometimes the "topper" is too tight a fit on the stopper and the hole requires another pass with a 3/8 bottom tap. As mentioned, hole depth a bit more than minimum required to give the glue squeeze out some place to go.
