It Takes Me About A Year . . .
charlie belden
>to forget why I don't turn much green wood - even if it was cut a month or two ago - from a supposedly dead tree. And it also takes about a year to forget why I don't turn punky wood.
My oldest pseudo-adoptee - now 28 - was thoughtful enough to bring me a 4 1/2" thick by about 26" acrossed slice of an oak tree from the ranch on which she lives (they raise sheep - and harvest only the wood - not a bad deal for the sheep). I promised her a bowl from this chunk of wood - and a promise is a promise - especially to one of your kids, pseudo-adopted or not, kid or not.
Turn a rough outside shape.
Super glue the hell out of all the punky areas.
Refine the outside shape.
Super glue the hell out of all the punky spots.
Sand the outside shape - and knock of some punky "stabilized" wood on the rim.
Return the outside shape.
Sand the outside shape - very carefully.
Start on the inside - after applying a BUNCH of MinWax Hardener - three times.
Turn the inside some.
Apply more hardener - and wait.
Apply a LOT more hardener - and wait - a LOT longer.
Turn the inside some more.
Rim starts warping to the point where you can't get anywhere even close to it with a gouge - or even the MiniMonster.
TRY and turn some more on the inside - but only near the bottom since everything else is now WAY out of round - and the wall thickness leaves no room for fixing.
Go back to THICK super glueing the punky areas - and wait (slow cure thick CA glue).
Now I've got this tear drop shaped rim bowl - that's STILL wet.
So I give it 20 seconds in the microwave - 10 minutes of resting and recupertating outside the microwave, followed by 30 seconds of microwaving. Now 15 minutes later, what I'd thought was a line of spalting (the source of all that punky wood) - was in fact - a very small, invisible in fact, crack - in the bottom of the bowl - which is NOW quite visible.
OH CRANUS! Never - ever - ever - turn green wood again! ( should write the date on the wall next to the lathe and in about a year remember to notice that date).
So about $15 worth of CA glue and another $10 worth of wood hardener later - I've got a spalted oak bowl - with a tear drop shaped rim - and a couple of cracks in the bottom - for my oldest "adoptee". I can fill the cracks in the bottom so they won't be noticable - the rim - well there's no fixing that - or the notches in the outside of the rim that came about in some mysterious way (I'm suspecting Punky Wood as the cause).
Fortunately, Marie loves things that are different so all in all this bowl is priceless (and I don't mean that as something no one would pay good money for, but rather a piece turned from a chunk of wood given to an "adopted dad" - who made something for the daughter who thought enough to give the wood to him in the first place.)
But THIS is the LAST green punky wood I'll turn. Swear to god. Honest! (got to do something about this memory loss thing).
