Will Nova Jaws work on a Oneway?
>I have a Oneway Stonghold chuck and a smaller Oneway (with the bars). I am looking at the Nova Soft Jaws - they look like a good idea.
So, will they fit?
TIA
Re: Will Nova Jaws work on a Oneway?
Steve Kubien
Steve Kubien
>I know they will fit the Talon (medium Oneway chuck, right?).
Steve
Russ Fairfield
>Nova jaws will fit the Onway scroll chuck and the Talon, but not the Stronghold.
Thanks
>I figure that they are a good investment then.
No, they will not fit *LINK*
bob elliott
>I have both of the smaller Oneway chucks and I always knew that the Novas would not fit those chucks.
Check this link to Sawmill Creek. Be sure to read both responses to the question posted:
Nova Jaws and Oneway chucks
Re: No, they will not fit
bob elliott
>After additional reading, I discovered that the reason is the "rib" on the back of the Oneway jaw has a taper and the Nova jaw "rib" has a square profile. The (Nova) square "rib" profile will not seat properly into the Oneway. But, conversely, the (Oneway) tapered "rib" profile will fit the square area on the Nova chuck.
With the Soft Nova jaws, it would not take much to grind away the rib section of each jaw. The only other obstacle might be the size of the countersink area of the Nova jaws. I think the Nova may use a screw with a smaller diameter head, and if using the Oneway screws, you'd have to enlarge the countersink holes on the Nova jaws...or maybe use Nova screws?
Re: Correction -the new ones DON'T FIT
Russ Fairfield
>They may or may not be interchangeable depending on the age of the Nova chuck.
After seeing a couple messages to the contrary, I took my chucks to Woodcraft last night and checked.
The new Nova chuck jaws DO NOT fit the Oneway chucks because the shape of the centering rings are different..
The new Nova jaws DO NOT fit my old Nova chuck for the same reason.
The old Nova jaws DO fit the Oneway and Talon chucks.
All Oneway jaws DO fit both Nova chucks after the retaining pin is ground away.
