Rechuck hollow form!
neptune1
>How would I go about rechucking this vessel? I did the hollow from the bottom and plugged and then I want to drill a 1/4" hole in the top and leave a thin flange on top. But I already finished the bottom!!!! Now what? Any jig ideas would be great. Thanks R
Re: Rechuck hollow form!
Re: Rechuck hollow form! *LINK*
Stuart Johnson
>Use a donut chuck.
doughnut chuck
Brad Vietje
Brad Vietje
>Well... that might depend on how much torque you need to finish the piece. I start and finish all hollow forms between centers, so that influences my suggestions. There may be other, better ways to go that I don't know.
Here are a few options:
1. Turn a block with a very similar profile, and hot-glue the HF into it, using the tail center to align the two pieces. You might only need 3 blobs of glue, but you have to move quickly to do this before the glue hardens up. You might use glue around the edge of the cup chuck, too.
2. Turn or use some sort of friction chuck, such as a bowl shape or a "V"-shaped piece, and complete the finish turning between centers, using the friction chuck to drive, and a cone center at the opening to keep it running true.
3. A cup chuck or jamb chuck would be a carefully turned shape that will hold the piece from one end by friction alone (could use glue to help, too). This has to be just the right shape to grab the piece and hold it securely without marring it badly. You can push it in firmly with the tailstock to keep it running true.
4. Make up a small chuck-friendly foot that is glued on. After all turning is nearly complete, finish turn between centers to remove as much of this foot as you need to.
5. If the top surface is finished now, you might be able to drive the piece between centers with a turned profile that mates up with the top lip and even an extension or dowel that fits the opening.
Maybe these ideas will help. I generally finish everything I can with the foot at the base, then finish turn and sand between centers, and remove most or all of the foot.
Let us know how it turns out...
Safe spinning,
Brad Vietje
Newbury, VT
Texian
>Might want to screw a waste block to the faceplate of the doughnut chuck and turn a recess to match and center your vessel bottom. Center the top with help from the tailstock and clamp the doughnut. Use some thin padding material under the bottom and around the doughnut.
Dick Hines
Dick Hines
>If you had access to a vacuum chuck that would work. The bottom of the vessel could be held in the vacuum chucm and the top turnerd. LIGHTLY
