turning aluminum
turning aluminum
Steve Kubien
turning aluminum
Steve Kubien
>Me again,
A friend works at an aluminum plant and he dropped off some 1" diameter rods, around 14" long. I want to turn a few pens out of this stuff. I know my Thompson tools are up to the job but what sort of speed should I be spinning at? 2500+ rpm? 1000 rpm? Lower?
Can you also give me your opinion of the pros and cons of wearing some sort of gloves while doing this. Should I be concerned about getting my hands cut to ribbons by the sharp aluminum or should I suck it up and me more concerned about getting my hand dragged into the lathe? My gut tells me to not wear the gloves but I am nervous about what to expect.
Thanks for this,
Steve
Re: turning aluminum
Re: turning aluminum *LINK*
Walter Ahlgrim
>The link attached to this post remands 600- 1000 feet per minute
on a metal lathe.
600 X 12= 7200 inches per minute.
1 inch diameter rod had a circumference of about 3 inches
7200 / 3 = 2400 RPM.
My gut says 500 RPMs and scraping cuts only with 3/8 parting tool
Walta
Link
Dick Hines
Dick Hines
>I have never turned aluminum but brass turnes good on a wood lathe. I use scrapers. Make you have safty glasses of a face shield. I wear gloves with the fingers cut off for wood and brass.
I worry more about the curlies from acrylic pen blanks than brass.
What ever you do be safe and post a picture when you get the pens finished.
Before you get in too deep Steve...
Scott Burr in Ben Lomond CA
>Do you know what kind of alum. it is? It's in your best interest (and safety to find out). It can be soft, and be hardened to an extreme. Look at the battle tanks in Afghanistan the thick armor plates are alum and very hard in it's self and to manufacture (i.e. cut machine).
Please take the time is figure out what you have there before starting on it.
I've turned lots of aluminum
>First of all you can turn it just like wood. I don't use slow speeds or high, just kind of in the middle. You will find out pretty quick. It's just like turning hard wood. Look for the curls and how fast or slow you move the tool. Then adjust the speed until you have nice curls and feel like you are in control of the tool.
I use bevel rubbing cuts most of the time. With proper speed and feed rate you get a finish that can be sanded with 220. If you push too fast or use dull tools you can get something that resembles tearout. Every once in a while a scraper works better. If you continue to get the little tearout things switch to scraping or shear scraping. Play with it an see. The Thompson tools really shine here because you need sharp tools to cut properly. The Thompson tools hold an edge much longer in aluminum than my other tools.
I have not had a problem with aluminum being too hard to turn. I have had it happen with copper and rarely with brass. With copper and brass you can anneal it just the opposite of annealing steel. Heat to red hot and quench. This softens them. I do not know how to soften aluminum but then I have never had a need to.
You don't need gloves unless you try to pick up the the metal after sanding. It will be quite warm then. I do try to sweep up afterwords because the metal slivers get stuck in your shoes, then the carpet and anywhere else they should not be.
Re: I've turned some aluminum as .....
Jamie Donaldson
>..well as other softer metals like brass, and I always wear a thin leather golf glove when doing most turning, just to give my hand some protection. That leather hide is tougher than my hand hide! You may find using a lubricant like WD 40 helps with the cutting, especially if you end up using a scraper to smooth the surface.
Steve Kubien
Re: Before you get in too deep Steve...
Steve Kubien
>No worries there Scott. I have worked with this same stuff before, making handles for gouges. Drilled the end and tapped some holes to hold the tool in place. Easy-peasy, pumpkin-squeezy. My goodness I have been around my kids too much!
Steve Kubien
Thanks for all the info
Steve Kubien
>Lots of good stuff here. Exactly what I have come to expect in this crowd.
I'll play around with it next week. Heck, I've got over 7 feet of this stuff so I've got the material.
Cheers,
Steve
Re: Thanks for all the info
>Steve It does have to be well supported or it will chatter. I've tried turning chunks about 1 1/2 by 5 with just one end in the chuck and man you have to take lite cuts. With the tailstock up you can get aggressive just like wood.
Brad Vietje
Re: I've turned some -- Different Experience
Brad Vietje
>I've only turned a little of the hardened stuff...
I made a spinning top for a fellow who makes custom Aluminum solar mounts for me. The stuff I was real hard, and turned VERY slowly... It cut beautifully, with very fine, continuous curls that are sharp. The tool advance had to be slow, the RPM's quite low -- less than 500 on a 1" diameter piece. Going faster did not help, and I suspect there was just enough heat buildup at the faster speeds to cause a problem.
The fine shavings built up quite a bit, and once grabbed and got wrapped around the piece. I'd recommend clearing shavings much more often than when working with wood.
It took me about 3 hours of fairly hard work to do what I could have done in 10 minutes in real hard wood. I was able to cut it, scraping didn't seem to work real well (maybe faster), but I was able to make a very fine pattern with the Stewart chatter tool.
So, I have to conclude that it really does matter which alloy you try.
Safe spinning,
Brad Vietje
Newbury, VT
