so I am going to blacken an ash piece with either gesso or Indian ink. Then I want to use some liming wax to hightlight the grain. Do I use a wipe-on poly or oil or lacquer or something in there at some point?
>Steve I use some sort of finish after I put the black on. It sort of depends on the look I want. If you don't put a finish on the wax fills everything, even the tiniest pores and will also change the color of the piece. That works perfectly when I do the red aniline dye with black shoe polish. I get a great looking burgundy finish with black pores.
For really contrasty black with white wax I will use a finish. The more build the finish the more it fills in the small details that the wax can't get to. Consequently I often use lacquer. Very thin if I want the wax to fill all the pores and a little thicker if I want it to fill just the larger holes. The finish also allows you to wipe more wax out of the areas you don't want to fill.
Most waxes are soluable to mineral spirits so if you don't like the look just rub and/or brush it off. If you put just a tiny bit on a rag it helps remove the wax on the smooth surfaces.
>Thanks John. This is what my (sizeable) gut was telling me but I wanted to be sure. Can I Beall buff after the wax or will that remove all of the wax? I know it will mess up the buffs themselves but that is neiither here nor there right now.
>If you want to buff afterwords you need to seal it. I have used a buff after a few weeks and it worked but it takes the wax a pretty good while to dry. Since I use lacquer most of the time I simply spray another light coat over to seal it. Always do a test. Some finishes will drag the wax out. I guess it's whatever solvent is in the finish.
