Vari Grind 2
Steve in NC
>I received the Woodcraft fyler yesterday and noticed an ad for a Vari Grind 2 attachment for the Wolverine sharpening system. Anybody tried this new holder out yet.
Steve
Vari Grind 2
Steve in NC
Steve
Bill Neddow
Steve Kubien
>I believe Bill has this in his shop. What are your thoughts on it Bill?
Re: Vari Grind 2
Russ Fairfield
>Yes, and it is worth the extra $30. There is no more running the tool over the side of the wheel, and the weight of the tool handle is no longer in control of moving the jig. It is locked in place and can't get away.
And you will appreciate the new tool clamp that gets rid of the leaf-spring and it doesn't slip. That is a $15 retrofit if you buy the old style jig.
I was skeptical at first, but one day I spent all of 5 minutes setting up the angles and other adjustments, and discovered this is a major improvement over the old style.
Re: Vari Grind 2
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>I fully agree with Russ -- a major improvement on an already excellent tool. In fact, I have bought a second one.
Re: Vari Grind 2
Barry Turner
>I bought the upgrade for the old-style vari-grind. It alone is a great improvement. I never could understand where the design with the leaf spring came from.......not at all like Oneway's normally excellent engineering. When I get a few extra bucks, I my try the Vari-grind 2 jig.
Re:It works very well, and as Russ........
Jamie Donaldson
>.mentioned, it is safer, especially for new grinderpersons. It is a complete package, including 1 mount for setting up a new grinder, but without a second mount all the grinding has to be done on 1 wheel unless you already have the old system.
One more related question please...
Marc Phillips
>I move the tool around on the wheel to avoid making a groove in the wheel...
With the new vari-grind is there a problem at all with wearing a groove in the center of the wheel?
I added the hold down bearing already... way better than that old spring steel thing...
Re: One more related question please...
>There is just enough "slack" built in that you can avoid making the groove and still not have the tool run off the grinding wheel. They seem to have thought of everything this time.
Thanks Bill
Marc Phillips
