A55 Smoothing Plane
Wood Hardener
Wood Hardener
Wood Hardener
Chet Gelnett
>What is best to use for a wood hardener? I have some spalted that is on the verge of being bad. I tried sanding sealer but that did not work very well. Next tried Minwax wood hardener and that works but is a little expensive and when sanding it clogs the paper.
Is there a way to make my own wood hardener or something else to buy?
Thanks
Re: Wood Hardener
Re:I believe the Minwax hardener is ....
Jamie Donaldson
>...basically thin lacquer, and I have refilled that can many times with lacquer thinned with a bit of acetone (maybe 5~10%)for my own hardener purposes. Otherwise you will need to buy thin CA glue by the quart!
Re: Wood Hardener
Re: Wood Hardener
Stuart Johnson
>I haven't tried it but I read (here or elsewhere?) about using 50/50 mixture of water and white glue. I'm not sure but I would think regular Titebond would work.
Re: Wood Hardener
Re: Wood Hardener
Peter Charles Fagg
>I have frequently used wood hardener before but I used it only on wet wood. I understood it needed to be wet to react as a catalyst?
Peter.
Re: Wood Hardener
My trials
keith zimmerman, Normal IL
>I have used thinned white glue and it worked, however, I had to soak the wood a while and wait for it to dry. It also needed to be applied several time.
I have used Minwax Wood Hardener and it also worked, but it has to be applied several times, which makes it very expensive.
The latest product I tried was spar urethane (Minwax Helmsman) thinned 50/50 with mineral spirits. This works very well and dries quickly, so it can be reapplied as often as needed without a lot of delay. It is also much more cost effective than the wood hardener.
keithz
Re: Wood Hardener
Re: My trials
Chet Gelnett
>What about applying a finish. Are you limited in what finish you can use?
Re: Wood Hardener
Re: My trials
>Keith does it clog sandpaper as bad as the woodhardener or Lacquer. I haven't tried the White glue thing yet and CA glue works but is too expensive for large areas.
Re: Wood Hardener
Re: My trials
Coyne
>I have had experience with two products designed for hardening wood, using them to virtually replace rotted wood at the lower ends of outside door frames. I have not used it on wood for turning, but will at some time in the future. I believe it is very thin two part epoxy (when mixed it is about the consistency of diesel fuel) and it penetrates a looong way in end grain. One is BoatLife Git Rot, available at marine stores. The other, and in my experience probably better for spalted wood, is made by Dr.Rot (www.rotdoctor.com). It is shipped direct, has lots of information on the website, and has worked well for me.
Coyne
Re: Wood Hardener
Re: Wood Hardener
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>O have tried all of the above, except the products mentioned by Coyne. They do work, but can take weeks to dry -- especially the wood glue and the one-part water based hardeners that are on the market.
My choice is Polyall 2000. It is a two-part polyurethane based hardener that penetrates very deeply and is dry in less than five minutes. It is probably similar to the BoatLife Git Rot and the Dr. Rot.
Re: Wood Hardener
Re: My trials
keith zimmerman, Normal, IL
>Chet, on all these pieces, I used an oil finish followed by buffing with tripoli and wax on my Beall wheels with no problems at all.
keithz
Re: Wood Hardener
Re: My trials
>Yes John, the wood I soaked in thinned white glue did clog sandpaper. That is the main reason I quit using it. The spar urethane/mineral spirits mix did not clog sandpaper for me.
keithz
Re: Wood Hardener
Epoxy
>... but not your everyday epoxy. When we needed to firm up spongy wood, we used a very thin epoxy (the consistency of, say, water, or thinner) that wicked itself into the punky wood through and through and cured beautifully. I forget the name of the product, but I'll bet my ol' partner remembers. If anyone wants to know, I'll ask him tomorrow.
Re: Wood Hardener
Re: Epoxy
>I've used System 3 mirror coat to firm up some punky wood. It gets very viscous when the thermal reaction takes place. It's bee so long since I did that I don't remember how it sanded. I do remember it firmed up the wood and penetrated very far.
Re: Wood Hardener
Re: Epoxy
Bernie Weishapl
>I use epoxy after it is mixed and then mix it with Denatured Alcohol to about the consistancy of milk. Yes it has to dry but the DNA takes the epoxy down into the wood. I left it dry for 24 hrs then turn and sand.
Re: Wood Hardener
Re: Wood Hardener One More Product
Stuart Johnson
>Another good product is Nelsonite. It is used by pool cue makers and works well. It is expensive at I think about $50.00 a gallon. It's thin and soaks in well but may require several coats or soakings.
Re: Wood Hardener
This is what makes the message board great
>Wow" How many ways to make punky wood hard! Now even a pool cue finish. Where else can you get such accumulated knowledge addressing a problem?
Re: Wood Hardener
>Wow-can't help but wonder why you would make a pool cue out of anything that would require hardening. They take an awful lot of stress. I'll look it up and see what I can find.
Re: Wood Hardener
Re: found this, I'll search more later
Re: Wood Hardener
try that again  *LINK*
http://www.brannenmillwork.com/pdf/Nelsonite.pdf
Re: Wood Hardener
found some references to Resolute
>Apparently this is a solution that is often used to replace Nelsonite as a wood hardener/preservative but I'm not having very much luck finding info on it. It seems that Knife makers and pool cue makers use these products to stabilize the wood so it doesn't swell and shrink as much.
Re: Wood Hardener
Re: found some references to Resolute  *LINK*
http://www.cuecomponents.com/nelsonite.html
Re: Wood Hardener
Re: Wood Hardener *LINK*
Tommy Holmes in NW FL
>Abatron LiquidWood. Highland Hardware carries it. I haven't tried this brand but have used something like it with a much quicker dry time, about 3 minutes. It works well. I'll look for the information on the product I have when I get home.
https://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=1277
