Variable Frequency Drive (VFD) Question
Philip Morris
>I have a Jet 1642 1.5hp with VFD motor speed control. Lately, I have been focused on boxes with fitted lids and hollowforms with fitted finial lids. The fitting process requires stopping and starting the lathe quite a bit.
Because of health issues, these items will probably be most of what I turn in the future. I was wondering if I am setting myself up for a controller failure.
Thanks,
Philip
Re: Variable Frequency Drive (VFD) Question
>I don't think so. There are two weak points in the system, both mechanical. The on/off switch and the speed switch. I use the on/off switch on my powermatic constantly. Other than the switch coming loose one time I haven't had a single problem. I did have problems with the remote switch getting dirty and not working.
They have 8 of the powermatics at the Craft Center where I teach and many of the students use the speed control to stop the lathe. I have not seen a single problems with this.
In my electronic experience it's usually these kinds of things that go bad rather than controllers, which is good because they are easily replaced.
Philip Morris
>John,
As always, thanks for such a thorough response.
I was hoping that the switch would be the weak link in that Jet's website lists the controller as being half the cost of the lathe :(
Thanks again,
Philip
Don Orr
>I have a Jet 1642 and have used it for several years without any problems. I turn it on & off probably many dozens of times during a turning session. Especially doing boxes.I use the switch, not the speed knob. The controllers are all solid state and have no moving parts. That is not to say they can't ever fail though. I think you'll do fine.
Bill Howatt
>Anything can fail and if your controller does fail it may or may not be related to switching it on and off. However, my preference with electronic stuff is to avoid needless powering up and down but others will disagree.
I don't know about the Jet but my General 260's VFD is powered up and idling when it is plugged in. The on/off buttons only switch the 24V supplied by the VFD to the forward/backward inputs on the controller to make the motor run. I leave it plugged in all with the exception of thunderstorms and if I know I will not be using the lathe for a week or more.
My General has a Forward-Off-Reverse switch on it and turning it to Off interrupts the 24V like the On/Off buttons. I would prefer using that mechanism to stopping the lathe by running the speed pot down.
Bill
Dick Hines
Dick Hines
>I had to replace the switch on my PM 3520 about a year ago. I have had the lathe since 2003 and it gets a lot of hard use. I had a switch on hand because I thought it was going bad once before. I blew out the switch out and it worked until last year.
A new switch was like $45 and a piece of cake to install. Took all of about 15 mins.
>Bill the Jet and Powermatic are the same way. You are only switching the 24volt circuit on and off. The controller is on anytime the machine is plugged in. I turn my machine off at the circuit breaker at the end of the day so the controller is off and hopefully a little more protected from surges and such.
Philip Morris
>Bill,
That makes a lot of sense. Thanks for the additional insight.
I tend to turn the lathe off with the switch as well, if for no other reason than I don't want to accidentally bump speed pot knob and have lathe start turning when I think it is off.
I have no problem replacing a reasonably inexpensive switch now and then. It's replacement of that black box (mine's actually white) that scares me.
Thanks again,
Philip
