>Had some power applied to her today! Forward works well. Backwards good, link belts like to forward for the most part.
I'm having problems with a bit of vibration. The belt from the head to the jack shaft works well. I have some interference issues with the belt from the jack shaft to the motor. Nothing a saw cut won't cure.
What I am worried about is the motor to jack shaft distance. I don't think I'm getting enough motor tension. I'm thinking of adding about 6-12" of likn belt on to the motor belt for more tension and weight on the whole system.
Wadda ya all think? I'm I nuts? Believe me it wouldn't be anything new...
Looks like you have sufficient wrap around the pulleys to work well.
Sounds like you were just trying to let the weight of the motor provide the tension from the pivot points. I would not stretch the motor belt out any more from your motor pivot just to keep your system as compact as you can. Better to add some type of spring tensioner or just a slotted arm you can lock in some tension. With just the motor weight you will probably always get a jump from the belts when they start up.
The pull from the motor belt in your normal run direction is low in relation to the jack shaft pivot so it is not putting a lot of tension in the jack shaft to lathe belt. Think it will just be a better system if you lock the two sections down.
Sometimes, when you use the weight of the motor or a spring to supply tension for the belts in a situation like this, the motor will begin to bounce up and down. And once it starts, it may tend to keep on bouncing. Here's why:
The motor pulls on the bottom belt to turn the jack shaft pulley. In turn, the belt pulls on the motor - action and reaction. Pulling on the motor tends to lift it, and it will rise unless constrained.
In the extreme, the motor may rise enough to reduce the belt tension to the extent that the belt slips ever so slightly. Then, the pull on the motor will not be as great, and the motor will go back down. As it moves down, the tension will increase, and another upward pull will be exerted on the motor. Again, the motor will rise, and a cyclic bouncing will occur. (By chance, is this the vibration you mentioned?)
The effect will be greater if the load on the motor is uneven, such as when turning a piece of wood of uneven density or when turning an out-of-round piece. In this case, you could possibly get a resonance at a certain RPM that would cause the motor to jump up and down a lot, which might be a bit scary.
So, my thinking is that the motor should be locked in place once the tension is set. All the lathes I've seen that use drive belts have a means for adjusting the tension by moving the motor, AND a means for locking it down once the tension is set.
Keep up the good work! Methinks you are better at this game than you want to admit. :-)
>Forgot to mention ... it's a good idea to keep the belt tension fairly light until you get into a situation where you really need the extra tension for a heavy load. If you happen to hang a tool in a piece of wood, you want the belt to slip.
>I made the cutout for the jack shaft pulley larger last night to clear the belt. That removed a bit of the vibration.
I re-mounted the motor and motor hinge to the top of the board the lathe is mounted to as well. This makes it a bit more compact, the motor doesn't hang below the lathe anymore. With this mod I was able to removed about 4" inches on the motors link belt. This removed a fair amount more of the vibration, but there's still some more work to do.
This set up is a breadboard/ prototype, so the whole thing will be rebuilt in the long run. Tonight, I'll move the jack shaft pulley a little higher so the motor will be right under it so the pulleys will line up almost vertically. If I remember my college engineering courses correctly, this should provide good tension to the belts and not be so tight that they'll slip if anything nasty happens while turning.
Thanks for the reminder about that Doc, and thank all of you for your ideas.
