Compressor problem
Compressor problem
Compressor problem
Carole Valentine
>I have a 26 gallon oil-less Husky air compressor that all of a sudden will not develop any pressure. It just keeps on running with no pressure build. I can't find any leaks anywhere. Any suggestions? I am NOT a mechanic, but when Jeff W. gets back in town, he said he would help me trouble shoot. I just thought I would ask for ideas before then. And yes, I know you get what you pay for...but I can't afford a better compressor right now. ;)
Re: Compressor problem
Barry Turner
>I believe oilless cmporessors use a diaphram. My guess is, yours is ruptured. If you have the space, Husky makes a 60-gallon/6 HP compressor that has served me well. I think mine was $429 at Home Depot about four years ago.
Re: Compressor problem *LINK*
Dick Coers
>Oh, oh. Maybe there is a history here. Did a Google for oilless air compressor troubleshooting and found this guy.
" My vertical Husky 32 gallon, 150 psi, oilless compressor blew its second compression pump in three years."
other Husky trouble
Carole Valentine
>Sigh...I know it's a cheap compressor (WL650703), but you would think it would last longer than 4 years with very light duty. I am still hoping it might be some thing simple like a pressure switch or a belt or something. If it isn't, then I will just have to do without a compressor for a while.
Cyril Griesbach
>This may be a more than obvious suggestion but did you check the pressure relief valve to make sure it isn't partially or fully open?
If you're unfamiliar with this it probably located in the area of the gauges and likely has a split ring on the top.
Carole Valentine
>Yep. Checked that.
Rick_Allen
>If you don't hear a leak then you are likely not compressing any air.
Yea I know that sound silly.
You can likely get a new liner and set of rings for the compressor from Husky.
The oilless compressors are known for noise and a short life. The usual points of failure are a leak in the tank, a leak in the drain valve, a bad regulator, a blown ring (or worn rings and liner but that results in a slow failure).
GalenV in Iowa
>I imagine yours has a piston and either an o-ring or fiber piston ring. They can get hot and wear out. They also have reed type valves that can fail. More than likely if it will not pump up if you feel near the intake you probably cannot feel any suction. You can get parts to repair the reed valves or the piston ring.
I would think if the safety valve has stuck you would air escape so probably not that.
I have seen units where the pressure switch would fail and since since these are usually low capacity units they can leak out out faster than they can pump up. Again you would hear air escape.
I assume the piston rod has not broke!
Just my 5 cents worth.
Galen
Yes I have a cheap Sear oiless compressor
Jorge Castaneda~Downeast Maine
>Carole,
i don't know why you need such a big compressor. In my carpentry I use a 2hp Hitacchi, (made in Italy), twin tanks, I paid something like $200.00 for it 6 years ago and have been using and abusing it since, sometimes as many as 6 air guns were used concurrently in a big job. It uses oil and care must be taken that has enough of it, but for the money, it has paid the investment many times.
Just a thought.
Take care
Jorge
I choose that one because it was the one I could carry...
Bill Turpin in WNC mountains
>A zero pressure leak can be almost undetectable. You could put some pressure on the system from another (portable) compressor. You could then find a leak with as little as 10/15 psi.
I believe with most of the others that your pump is bad.
