PhotoShop to Analyze Proportions from Photo
charlie belden
>Paul Z. posted a photo "3 Pedestal Forms" earlier that got into a discussion about proportions - height to major diameter, % above and % below horizontal centerline, the Rule of 3rds ( I like the Rule of 5ths -2/5ths above, 3/5ths below), etc..
Lacking actual measurements, the discussion was subjective - "It looks to me like . . ."
Of course that's how we see and experience a piece - subjectively. But underlying the subjective, there's often some actual, quantifiable, relationships that can be analyzed (OK, so I was trained as an engineer and I'm the only one who wants numbers and ratios and percentages) - and used in future pieces we do.
So - I brought Paul's photo into PhotoShop, got some numeric data using PhotoShops "guides" and "rulers/scale" and popped some of those numbers into a spreadsheet to get some ratios and percentages. ( I can't help it, my dad was an accountant and I've been playing with numbers since I was three - maybe 4.)
Surprise, surpirse, surprise. The two I preferred are close to The Rule of 5ths - 2/5ths (40%) above centerline, 3/5ths (60%) below centerline.
And the height to major diameter more or less followed one part of The Rule of 3rds, the height being about 3 times the major diameter.
The one that several respondents felt was too centered - the middle one - isn't actually centered - but is close enough to centered (4% off) to be perceived as centered.
Studying, quantitatively, pieces that you subjectively like can be quite useful when you start working out the proportions of the next piece. PhotoShop (and I'm sure other applications) is a great design tool, in addition to all the image manipulation features it has.
Try it. You might discover The Secrets of Perfect Proportions - or not. Either way, you'll probably learn something useful - or not.
Just something to consider.
