>OK, here's a follow-on question for when I get the disc finished.
I've never used a disc sander before, and I could use some advise on safety and practicality.
When I attach the sanding disc to my lathe spindle, should I just sand things in the lower left quadrant like when sanding turned items, or should I set up a table/platform at mid height (probably in the tool rest banjo) and work in the upper left quadrant? My lathe doesn't reverse, so I can't mess with that aspect.
I expect some of you have done this. Please tell me the best approach.
Most importantly, what should I absolutely not do, and what should I 'probably' not do?
Your guidance will be greatly appreciated. ...Gary
>Gary, here's probably the most important idea: Always present the work to the disk in such a manner that the friction between the disk and the workpiece tends to push the workpiece away from the disk.
For example, suppose you wish to sand the nubbin off the end of a tool handle you've just turned. If you touch the end of the handle to the disk at 10 o'clock, with the handle pointing upward, it will grab and pull the handle downward rather sharply. However, if you touch the end of the handle to the 8 o'clock position, with the handle pointed slightly downward, everything will be smooth.
Basically, you can sand anywhere on the disk as long as you obey this one rule. And you can get into trouble anywhere on the disk if you violate this rule.
Here's an experiment you can do. Take a piece of rubber hose or plastic tubing a few inches long, and with the disk turning slowly, touch the end of the hose to the disk. If you point the hose toward the oncoming grit, it will grab. A drinking straw will also work, or anything flexible enough to bend harmlessly. Even a piece of paper rolled up into a fairly tight tube will illustrate the idea.
My suggestion would be to start with a piece of scrap wood and a fine grit, like 220 or 320, with the lathe turning as slowly as it will go. Be sure the tool rest and banjo are out of the way.
A major hazard in using the disk is the possibility of accidentally letting a hand or finger contact the outside corner of the disk at the outside edge of the sandpaper. This can happen very quickly if the disk grabs the workpiece, and it is, at the very least, painful and thought provoking.
What type objects do you anticipate sanding? If we knew that, perhaps we could be more specific in our advice and suggestions.
>Gary, I had a 6x10 inch piece of flat steel welded to a 1" rod to fit into my banjo. The rod is welded not in the middle but about 1/3 of the way down the long axis of the plate.
Doc Green's advise is very sound and using a table like I describe does not alter his advise in any substantial way.
At hardware store pick up a "floor flange" in the plumbing section.
This is a round disk that is threaded in center for a piece of metal pipe. It also has 4 holes around the perimeter for screws. Screw it to the bottom side of a 3/4" piece of plywood, if you cover the top side of the plywood with counter top (formica) material it's that much better.
First though, determine the size (diameter) pipe you need, determined by the hole size of your banjo. If it is 1" you'll of course need a flange threaded for 1" pipe and then a short piece of pipe that size.
>Thanks Cyril, That's the kind of thing I had in mind. I don't know a welder, but I'm sure I can find one if I don't take Don's tip and make one out of pipe and plywood. ...Gary
>Doc, Thanks for taking the time to write that excellent description. Because we "can't prove the negative", we will probably (hopefully) never know about the accident you saved me from, but you probably did. I appreciate it. ...Gary
