Diamond grinding wheels for your gouges?
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>Is anybody using the new diamond grinding wheels? I have had one for 2 years now and am very impressed -- but what experiences have others had with this new (to woodturners) tool?
Re: Diamond grinding wheels for your gouges?
Rick_Allen------WebKitFormBoundaryBB6jehnivTdA+V7w
>The diamond wheels have been around for many years. The can be easily "grooved" when sharpening a bowl gouge. Once they are "grooved" (diamonds removed in a line) they are very much less effective.
For flat edge tools like skews, pairing chisels, plainer blades the diamond wheels are very effective.
You can grind gouges on a diamond wheel without damaging the wheel. You should maintain a very light touch so the "glue" holding the diamonds doesn't soften, which damages the wheel
This is fairly old (10+ years) thinking. The topic of diamond wheels comes up every few years and the effect has been the same.
Re:Except now they are readily .................
Jamie Donaldson
>.....available for a reasonable price at Woodcraft stores. I've been using one there while doing demos, and haven't decided whether to replace my SG 120 wheel on my main grinder because I use the rounded edges for sharpening my hollowing tool bits? Don't know if that could be easily done with the diamond wheel?
>Jamie, If you are using the new CPM 10V tools like those Keith Thompson makes, sharpen on your SG wheel and then "hone" on a 180 grit diamond wheel. You will get a scary sharp edge that will actually stay on the tool and not break off. (I don't think M2 is strong enough for this.) The result will be an immediate improvement in the quality of the finish you get from the tool. I was able to almost do away with the coarsest grit I used to use by adopting this technique.
Re:The only Thompson tool that ......
Jamie Donaldson
>.. I bother to hone is the detail gouge, and I hand hone with a credit card sized diamond flat.
