Water marks on wax question.
>I have a turning I would like to post a picture of, but I buffed it and put carnauba wax on it. It is a "working" turning and got water on it and it has spots. Is there a simple way to remove the spots?
Re: Water marks on wax question.
John Veerkamp, Western Mo
>Try buffing it again. If that doesn't work you may need to wipe it down with mineral spirits and then re-wax.
John
Dick Coers
>Is there lacquer under the wax? If so, the water marking may be in the lacquer and not the wax. I don't think water will mark most waxes, but maybe if it sat on there long enough?
RussFairfield
>The good part about wax is that it is easilly renewable with another coat of wax. Use less wax the next time and buff it with a scrub brush to remove all of the excess and compact the wax on the surface. Less wax and compacted makes it more resistant to water spots.
Use Renaissance Wax if water is going to be a problem. Mineral waxes are more water resistant that vegetable waxes.
If the water got to the wood or the finish under the wax, and the spotting is permanent, you will have to sand and refinish the wood. No amount of wax will cover a finish that has been damaged with water.
Scott in SoCal
>I totally stopped using carnuba because of this - it water spots badly, and short of de-and-re waxing the piece, they won't come completely out. Renaissance wax is my wax of choice now, it's much more tolerant.
A good hard hot buffing with the wax wheel would sometimes work on the water spots, you might try that if the piece can stand the heat.
Bernie Weishapl
>I quit using Carnuba wax because it is a pain especially when you get water spots, finger prints, etc. I went totally to Ren Wax.
