Book Review *LINK*
Book Review *LINK*
Book Review *LINK*
>I just finished "Inlace Techniques" by Betsey Sloan. She is a gourd artist and does some really cool things with Inlace and carving on gourds. Since I have used a fair amount of the stuff I thought I would get her book. She covers the topic really well but I think she's a little too picky about adding the hardener. I've found that as long as you add enough your OK. If you add to much it's not a problem unless you double the amount or something like that. Just err on high side and not the short side when adding the hardener.
She does recommend using the thickener which I have never used. I will have to try it sometime. When I need thicker Inlace I just let it sit until it starts to harden but then your working window gets much smaller.
Because they are gourds she does all of her leveling with a sanding drum or disc. We are fortunate in that we can put the piece back on the lathe and cut the overfill away. Then sand it smooth. If you want Inlace to really be glossy you need to go further than 400 grit although a finish that builds will usually take care of the gloss after this. If you use an oil finish sand the Inlace to ahigher grit.
What she doesn't address in the book is pinholes. She does talk about air bubbles but I don't have much problem with them. Sometimes I usually patch the pin holes with CA but sometimes it won't fill the hole, it just covers the surface so you have fill it 2 or 3 times which gets kind of frustrating. I may have to try putting the CA on the holes and then poking them with a needle to see if I can force the CA in, or air out, or both.
I have been buying my Inlace from the place she recommends which is Turtlefeathers.net They have by far the widest selection of Inlace and fillers. In fact if you need an fillers for epoxy this is the place. He has metal powders and all sorts of crushed materials.
If you have not done Inlace this is a good book and it's cheap through Amazon.com
http://www.turtlefeathers.net/
Re: Book Review *LINK*
Re: Book Review
Rick Bane
>John, I want to thanks you for the link. I just ordered an Inlace kit to try. Dave was very nice and also sending me some samples of metalic dust and stone flakes to try. I have been wanting to try some sort of inlay to my turnings and your timing was perfect! Thanks again! Rick
