tiny screw eyes for ornaments
joazhill
>Anyone know where I can get these for the tops of ornaments??
TIA
Re: tiny screw eyes for ornaments
Paul Zerjay
>True Value
RussFairfield
>I cut the eyes off of fish hooks, roughen the shank with sandpaper and hold it in a small hole with CA glue.
Harv in Dewey
>I make them out of thin wire. Make a lope and put a small nail in the lope and twist the wire and cut off the excess. The twisted wire acts like a screw. But I always glue it in place.
>I use several. The one on the left and the second one are earing hooks that buy from Hobby Lobby. I take the the first one and straighten it to look like the second. Then I cut is shorter to install in the ornament. These are nice looking but a little fragile if you bend them 90 degrees a few times they break.
The third one is another jewelry making piece I also get from Hobby Lobby. They are a little tougher, but not quite as nice looking.
The 4th one are little bitty eye hooks. These are actually too small. I bought them from a hobby shop that sells parts for RC planes.
The 5th is a bait saver fish hook. These have barbs that point toward the eye so you drill a hole the size of the shaft and just push it in. These are extemely tough and you can't break them. they are unfortunately also very hard to cut. You need big heave linemans pliers or cable cutters. They come in Black, nickle and gold and in different sizes.
The last 2 are homemade. I wish I could remember who sent this in as a tip. I could probably find it but it was 4 or 5 years ago. They are extremely easy to make and you can use all sorts of wire. I'll show how to make them below.
>To make the homemade hooks you need to build a jig. Take a dowel rod, cut off part of the end and then insert a nail through a hole drilled in the ends. Cut the nail off. Now take a piece of wire and bend it in half. Grip the wire in pliers and hook the loop over the nail. Put the dowel rod in a drill, hang on to the pliers and twist the wire with the drill. Cut the twisted wire to length and you have a hanger.
Rob Wallace
Rob Wallace
>John,
You could just as easily chuck the free ends of the wire loop into the Jacobs drill chuck in your favorite cordless drill and twist the wires more evenly and more quickly than you can with pliers or vise grips. One might need to experiment with slightly longer wire lengths, but the efficiency of twisting will go WAY up by using a powered drill chuck.
I was taught to do this technique when building electronic/radio equipment "from scratch" (i.e. ham radio), particularly when you need twisted pairs of wires that will run to the same place (such as with tube filament circuits). Makes the chassis assembly of whatever you are building that much neater. ( BTW, that's OLD SCHOOL ham radio, when people built a lot of their own equipment! 73 DE WA0RW)
Rob Wallace
Dick Coers
>I get mine at Hobby Lobby. They are a fraction of the cost compared to the True Value. The eyes are in the wood craft section.
Bernie Weishapl
>I make mine like John shows. I sit watching television and make them up about 100 at a time. Cost isn't worth figuring.
>Rob Your only holding the pliers, the drill does the twisting. I have a lathe that will slow down so I use the chuck and lathe to hold the dowel.
Steven Antonucci
I do this, but manually
steve antonucci
>I wrap the wire once around a small screwdriver shaft and twist it once or twice. I then grab the two loose ends and make a couple more turns until everything tightens up. If the ends are uneven, I clip them with wire cutters. No need for a drill, and they only need to be 1/2" at best...
S
Dick Hines
Dick Hines
>I use the third form the left. I was useing the screw eyes but the store that I was getting them from stoped carring them.
Like Russ said take a piece of sand paper and rough up the shaft so the glue will have something to grab.
Bill Crommett
>I use the little screws that I bought for making fishing plugs. I don't remember where I got these, but try some of the outdoor equipment places on line.
Mike Peace
Re: tiny screw eyes for ornaments *LINK*
Mike Peace
>They have them in silver or brass plate. I would get the smallest ones.
Bennyswoodworks
Jesper, Denmark
Re: Brilliantly simple solution.......
Jesper, Denmark
>Now why didn't I think of that?
Small Brass Eyes- Michaels
Barbara Gill, Remlik VA
joazhill
>Wow, ask and you shell receive. I can always count on this forum to get the answer no matter how tiny the question.
Thanks all..........Joaz
Wire hanger - no twist
Doc Green
>I use a wire loop but don't twist the wire. However, I drill a tiny hole all the way through the finial, run the wire through the hole, and then flair the ends of the wire slightly where it exits at the bottom of the finial. A spot of CA at that point seals the deal.
To make a hanger, I form the loop by wrapping the wire around a drill bit then use needle-nose pliers to bend the ends of the wire until the two ends stick out radially from the loop.
Not twisting the wire allows the use of a smaller hole and avoids the application of CA to the top of the finial where it can stain the wood.
~Doc
Lan Brady
>I have tried most of the options listed below/above. All work well.
I buy the eyes at Michaels, Hobby Lobby or AC Moore.
One more option to add to the collection! I use a pin drill and create a very tiny hole in the end. Loop fishing line and insert both ends. It sticks to CA glue real well. An added advantage, when hanging on a tree , the ornament appears to be floating with no visible means of support.
Good Luck, you have many options, Lan
24 ga. brass wire works fine. have made hundreds
bob davis
that is what i do
bob davis
Barry Turner
>I'm with you. I snip off fish hook eyes to use as eyelets. I prefer the blued hooks, as I think gold plated screw eyes or hooks can detract from the appearance of a nice ornament and make it look cheap. But that's a personal opinion. I find the hook shanks with barbs work best.
Brad Vietje
That's what I do -- I've never bought 'em...
Brad Vietje
