Veritas - Innovation in Tools
Dye application to wood turnings *LINK*
Dan Oliphant
>Over the last few months I have been working on a process to dye woods in multi colors. The only detailed info that I found before this effort was for guitar bodies.
I have written the process up and would like to share it with those that are interested. Any improvements to the process would also be appreciated.
Applying alcohol based dye to wood turnings
Re: Dye application to wood turnings *LINK*
color-fastness
mfosterVT
>I just took a class with Gary Sanders on coloring wood at the John C. Campbell folk school. Gary has done extensive testing and research with regard to colorfastness of all pigments. He has found that all dyes fade over time. Certainly, if they are exposed to direct sunlight, they will fade faster. Using a finish that has UV protection may help prolong the color intensity. Dyes are easier to use, and can provide a deeper, more vibrant color than other pigments, however.
so, if you are looking for an easy way to get nice colors, dyes are a good choice. If you are looking for more archival quality colors, inks and translucent paints may be a better choice.
Mike
Re: And here's another disclaimer....
Jamie Donaldson
>... for the question of archival qualities of colorants. Since taking the class with Gary and Mike, I've been researching the variety of dyes/pigments available. The metallized acid dyes like TransTint are claimed to be more light stable than aniline type dyes, and I am in the process of acquiring some for application testing. Turner Don Derry uses metal acid dyes extensively in his very colorful work, and I expect to learn more about their useability in the near future.
GaryG in MD
>Thanks Dan -- this is very timely for me. I have bought some dyes but not had the nerve to start applying them yet. This will help. ...Gary
Paul Zerjay
>Whats wrong with shooting your dye with an airbrush? Seems to work pretty well for me. I use an alcohol based leather dye from Fiebing. Dries quickly and comes in a variety of colors.
question...
GaryG in MD
>Dan, Could you say a few more words about the particular spray bottles that "do not" and "do" work? Types, brands, characteristics, etc. Thanks, Gary
Re: question...
Dan Oliphant
>Gary,
the spray bottles that did not work are the 4 oz. craft bottles sold at Michael's Craft stores. The bottles that worked well are called "igo" made by Bottle Crew, and sold in the health and beauty section at WalMart. If someone tries the igo bottles, close the nozzle after spraying. If not the bottle will drip dye until it is empty.
Paul, An airbrush set up will work just great too. I was not prepaired to go that route while learning from scratch. I do think an airbrush is most likely an excellent end point if one decides to continue using a dye process.
Thanks, Dan...
GaryG in MD
>I appreciate the info.
If you're on WoW, have you looked at Joe Landon's work?
www.thewows.com/isapi.dll?c=Content&htx=List&siteid=G6kOAI&contentclass=PICT&categoryid=1297
If you're not, I reco that you try it. I can get you on if you want to. ...Gary
Re: I have found that wiping on the.....
Jamie Donaldson
>...dyes gives me much more control, and doesn't put all that nasty stuff in the air, but often on my fingers instead!
leppikallio
>However if one dyes over sealed surface, spraying gives much better results. Just because the surface don't suck that dye as well/fast as without sealing.
