Re: controller for general 260 lathe *LINK*
Curly Smith
>I doubt that you'll find anybody that will economically fix your controller.
At the link you'll find 2 different drives for a 2HP motor that may work for your motor. Both are for 220v Single Phase in and 220v Three phase out.
The top drive is a variable torque drive and costs $200. The bottom drive is a constant torque drive and costs $300. I suggest you call them to talk about the differences between the drives and how those differences impact motor performance. You need to match the controller to both the motor and the intended use.
There are many places to buy controllers (another is Dealerselectric). I selected the link because it gives you easy access to the two distinct types of drives and motor performance info. As an example, the Constant Torque unit says
"High starting torque of 200% or greater at 1Hz
Newly developed technology - Intelligent Sensorless Vector Control - cope provides optimal high torque without motor tuning."
I don't know if that matches the performance of your old unit or not but the reps at either DrivesWarehouse or Dealerselectric will.
Variable Frequency AC Drives
